Hello how are you . First of all thanks for the help and sorry if it is not in the correct section, I am new to the forum.
My query if it is possible to set up different redirects by https, for example
I have a fixed public IP which connects to the mikrotik and from it I must distribute different subdomains.
example.domain.com
towards a server 192.168.1.1 port 443 with certificate.
example2.domain.com
towards a server 192.168.19.1 port 443 with certificate.
example3.domain.com
towards a server 192.168.5.67 port 443 with certificate.
I try to do it from the web proxy but I can only with port 80.
I'd appreciate your help.
Thank you
