1) Which one should I use to get data for monitoring? Is there a difference in resource consumption between them?
2) How can I profile the resource consumption of my API or SNMP calls? I want to set a bunch of automatic tests to measure mikrotik resource consumption with some specific calls, I still have not come with a good way to do it.
Appreciate your attention.
