Hello there
via mikrotik device;
I want to login with remote pfsense freeradius connection
I'm waiting for your help?
To use your pfsense/ freeradius as a login for mikrotik.
Use winbox :
RADIUS -> check the login button & add in the IP address of your pfsense box & add in your pfsense/freeradius login password.
On System->UserList, click the AAA, and check the "use Radius"
Thats it.
Well your radius service needs to be made routable to your mikrotik-router, or put pfsense on your local LAN segment.
