Sun Jan 10, 2021 6:44 pm
It depends on whether you want to use WinBox or not. L2TP don't have much to do with it. If you want to use WinBox only over L2TP, you may limit allowed sources in "Available From" (or you can do the same using firewall filter), but you can't disable it completely.
Excessive quoting is useless and annoying. If you use it, please consider if you could do without it.
