Mon Jan 11, 2021 4:26 pm
There is no "correct" way as the machines are different model (for migration to exactly the same model, backup/restore is permitted and even recommended).
The process is relatively easy if the machines run the same RouterOS version, in that case, export on the 1100 can be copy-pasted line by line to the 3011 previously reset to defaults. Unfortunately, practical experience shows that some incorrect settings which older version of ROS has accepted are happily exported by a current version but not imported. So /system reset-configuration run-after-reset=the-export-from-1100.rsc fails in such case.
If the RouterOS releases are different, the structure of the configuration of same things may look different, and some functionality may not be available in the newer version (like auth-metod=pre-shared-key-xauth with exchange-mode=ike2 has been removed starting with 6.45.something).
As you mention GRE in particular, there was a security patch in 6.45.something which has made the firewall mistreat GRE - received packets whose connection-state is actually new are labeled with connection-state=invalid, so you have to add protocol=!gre to the action=drop connection-state=invalid firewall rule in filter chain input if your firewall is based on the default one, or address that in some other way if it is not.
Just for the sake of completeness, of course you also have to deal with the fact that a 1100 was a 13-port machine whereas the 3011 is a 10-port one, so you have to move any configuration referring to ether11-ether13 to other ports or drop that part completely.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
