hneel
What are correct basic rates for 5GHz?
Wed Jan 13, 2021 1:10 pm
My AP is a Hap AC2.
I have a problem with Windows laptops that can't connect to 5Ghz band. Android phones however have no problem.
A snippet from the (long) error report from Windows:
Gedetailleerde hoofdoorzaak:
802.11-verbinding is mislukt door statuscode 18: de koppeling is geweigerd omdat het aanvragende station niet alle gegevenssnelheden in de parameter BSSBasicRateSet ondersteunt
Sorry, it's in dutch. It says that there's something wrong with the basic rates.
What are the correct settings? At first it was 'default'. According to inssider that meant 6mbps. I've tried to add 12 and 24, like I saw on another AP, but that didn't help.
hneel
Re: What are correct basic rates for 5GHz?
Wed Jan 13, 2021 1:16 pm
Here are my settings:
[admin@MikroTikZolder] > export
# jan/13/2021 12:12:59 by RouterOS 6.45.8
# software id = UXTY-27Y3
# model = RBD52G-5HacD2HnD
# serial number = XXXXXXXXXXXX
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country=netherlands disabled=no frequency=2462 mode=ap-bridge name="wlan1 (2.4)" ssid=XXXXXXXXXXXX wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac basic-rates-a/g=6Mbps,12Mbps,24Mbps channel-width=20/40/80mhz-XXXX country=netherlands disabled=no frequency=auto mode=ap-bridge name="wlan2 (5)" rate-set=configured ssid=XXXXXXXXXXXX supported-rates-a/g=6Mbps,12Mbps,24Mbps,48Mbps,54Mbps wireless-protocol=802.11
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=XXXXXXXXXXXX wpa2-pre-shared-key=XXXXXXXXXXXX
/ip hotspot profile
add bridge=bridge1 interface="wlan1 (2.4)"
add bridge=bridge1 interface="wlan2 (5)"
add interface="wlan1 (2.4)" list=WAN
add interface="wlan2 (5)" list=WAN
add interface=ether1 list=LAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add address=10.0.0.91/24 interface=ether1 network=10.0.0.0
set servers=8.8.8.8
add distance=1 gateway=10.0.0.98
/system clock
set time-zone-name=Europe/Amsterdam
/system identity
set name=MikroTikZolder
normis
Wed Jan 13, 2021 1:23 pm
The defaults should work with any windows laptop. Try this command:
/interface wireless> reset-configuration wlan1
bpwl
Wed Jan 13, 2021 2:21 pm
(Deepl.com translation:)
Detailed root cause:
802.11 connection failed due to status code 18: The link has been rejected because the requesting station does not support all the data rates in the BSSBasicRateSet parameter
What it says .... your Windows PC (requesting station) does not support the Basic rates announced by the AP. In other words: the AP announces basic rates "basic-rates-a/g=6Mbps,12Mbps,24Mbps" , but the Windows PC does not support all of them. The PC may support 6 Mbps but maybe not 12 or not 24., or just another combination.
If you play with "basic rate/supported rate" make sure you understand what they mean and when they are used, or just don't fiddle with them. Using basic rates 6,12,24 is a bit odd in this. (I would understand 6 or 6,9,12 or 9,12,18 or 12,18,24 or 18,24 or 24 for basic rates. Mostly the lowest value is used. 6Mps is always used for the first request from the client even if disabled on the AP.) Supported rates must always include all basic rates and normally have more (higher) rates. These supported rate settings must support all basic rates indicated on both devices.
So the error says: the supported rates on the Windows PC do not include 6,12 and 24 Mbps, which are announced by the AP.
hneel
Wed Jan 13, 2021 4:31 pm
I did this (except on wlan2, wlan1 is on 2.4Ghz and had no problem). Then I set some basic settings and now it works again!
set [ find default-name=wlan1 ] band=2ghz-b/g/n country=netherlands disabled=no frequency=2462 mode=ap-bridge name="wlan1 (2.4)" ssid=XXXXXX wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n country=netherlands disabled=no mode=ap-bridge name="wlan2 (5)" ssid=YYYYYY wireless-protocol=802.11
It's not optimal yet though, so I will optimize it one step at a time now.
Thanks!
Users browsing this forum: bandini981, Bing [Bot], Kindis, ros44, volkirik and 211 guests
