samreiss
CAPsMAN with Local Forwarding & VLANS Router/Switch/AP (hAP AC)
Thu Jan 14, 2021 6:25 am
I am configuring a hAP AC to be a Router/Switch/AP all-in-one using CAPsMAN (I do have other APs that I'll add later, but I need to get this configuration worked out first). Here's the objective:
-3 VLANS (Private=20, Public=21, Kids=22)
-3 SSIDS to align with each VLAN
I am able to connect to SSIDs, but they do not pull an IP address from the DHCP server. Also, I can't access winbox configuration on the Private SSID. Thoughts? See anything wrong? Here's export of the configuration:
# jan/02/1970 02:00:41 by RouterOS 6.43.7
# software id = JVFK-X1M2
# model = RouterBOARD 962UiGS-5HacT2HnT
# serial number = 8A7D08DEEF06
/caps-man channel
add band=2ghz-b/g/n extension-channel=XX name=2ghz reselect-interval=1m
add band=5ghz-a/n/ac extension-channel=XXXX name=5ghz reselect-interval=1m
add admin-mac=CC:2D:E0:E0:8D:3B auto-mac=no ingress-filtering=yes name=bridge \
    pvid=20 vlan-filtering=yes
/interface wireless
# managed by CAPsMAN
# channel: 2462/20-eC/gn(28dBm), SSID: PRIVATE_CAP, local forwarding
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto mode=ap-bridge name=wlan2ghz \
    ssid=DEFAULT wireless-protocol=802.11
# channel: 5180/20-Ceee/ac(27dBm), SSID: PRIVATE_CAP, local forwarding
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto mode=\
    ap-bridge name=wlan5ghz ssid=DEFAULT wireless-protocol=802.11
/interface vlan
add interface=bridge name=vlan-20-private vlan-id=20
add interface=bridge name=vlan-21-public vlan-id=21
add interface=bridge name=vlan-22-kids vlan-id=22
add interface=bridge name=vlan-23-vpn-mn-stillwater vlan-id=23
/caps-man datapath
add bridge=bridge client-to-client-forwarding=yes local-forwarding=yes name=\
    datapath-20-private vlan-id=20 vlan-mode=use-tag
add bridge=bridge client-to-client-forwarding=no local-forwarding=yes name=\
    datapath-21-public vlan-id=21 vlan-mode=use-tag
    datapath-22-kids vlan-id=22 vlan-mode=use-tag
/caps-man security
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm \
    group-encryption=aes-ccm name=security-20-private
    group-encryption=aes-ccm name=security-21-public
    group-encryption=aes-ccm name=security-22-kids
/caps-man configuration
add channel=2ghz country="united states3" datapath=datapath-20-private mode=\
    ap name=cfg-20-private-2ghz security=security-20-private ssid=PRIVATE_CAP
add channel=5ghz country="united states3" datapath=datapath-20-private mode=\
    ap name=cfg-20-private-5ghz security=security-20-private ssid=PRIVATE_CAP
add channel=2ghz country="united states3" datapath=datapath-21-public mode=ap \
    name=cfg-21-public-2ghz security=security-21-public ssid=GUEST_CAP
add channel=5ghz country="united states3" datapath=datapath-21-public mode=ap \
    name=cfg-21-public-5ghz security=security-21-public ssid=GUEST_CAP
add channel=2ghz country="united states3" datapath=datapath-22-kids mode=ap \
    name=cfg-22-kids-2ghz security=security-22-kids ssid=KIDS_CAP
add channel=5ghz country="united states3" datapath=datapath-22-kids mode=ap \
    name=cfg-22-kids-5ghz security=security-22-kids ssid=KIDS_CAP
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp-pool-20-private ranges=192.168.20.10-192.168.20.254
add name=vpn ranges=192.168.89.2-192.168.89.255
add name=dhcp-pool-21-public ranges=192.168.21.10-192.168.21.254
add name=dhcp-pool-22-kids ranges=192.168.22.10-192.168.22.254
add name=dhcp-pool-23-vpn-mn-stillwater ranges=192.168.23.10-192.168.23.254
add address-pool=dhcp-pool-20-private disabled=no interface=vlan-20-private \
    name=dhcp-server-20-private
add address-pool=dhcp-pool-21-public disabled=no interface=vlan-21-public \
    name=dhcp-server-21-public
add address-pool=dhcp-pool-22-kids disabled=no interface=vlan-22-kids name=\
    dhcp-server-22-kids
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration=\
    cfg-20-private-5ghz name-format=prefix-identity slave-configurations=\
    cfg-21-public-5ghz,cfg-22-kids-5ghz
add action=create-dynamic-enabled master-configuration=cfg-20-private-2ghz \
    cfg-21-public-2ghz,cfg-22-kids-2ghz
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged \
    ingress-filtering=yes interface=ether2 pvid=20
add bridge=bridge interface=ether3 pvid=21
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add bridge=bridge interface=sfp1
add bridge=bridge interface=wlan2ghz pvid=20
add bridge=bridge interface=wlan5ghz pvid=20
/interface bridge vlan
add bridge=bridge untagged=ether3 vlan-ids=21
add bridge=bridge untagged=ether2 vlan-ids=20
add bridge=bridge vlan-ids=22
add bridge=bridge vlan-ids=23
/interface l2tp-server server
set enabled=yes use-ipsec=yes
add interface=bridge list=LAN
add interface=ether1 list=WAN
add interface=wlan2ghz list=WAN
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
/interface wireless cap
set discovery-interfaces=bridge enabled=yes interfaces=wlan2ghz,wlan5ghz
add address=192.168.20.1/24 interface=vlan-20-private network=192.168.20.0
add address=192.168.21.1/24 interface=vlan-21-public network=192.168.21.0
add address=192.168.22.1/24 interface=vlan-22-kids network=192.168.22.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
    ether1
add address=192.168.20.0/24 gateway=192.168.20.1 netmask=24
add address=192.168.21.0/24 gateway=192.168.21.1 netmask=24
add address=192.168.22.0/24 gateway=192.168.22.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.20.1 name=router.lan
    established,related,untracked
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
    protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
    invalid
    disabled=yes in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
    192.168.89.0/24
/ppp secret
add name=vpn
/system identity
set name=BASEMENT
/tool mac-server
/tool mac-server mac-winbox
sindy
Re: CAPsMAN with Local Forwarding & VLANS Router/Switch/AP (hAP AC)  [SOLVED]
Thu Jan 14, 2021 9:09 am
Set the pvid parameter on the /interface bridge row to some unused VLAN ID, e.g. the default 1, and add tagged=bridge to all four rows in /interface bridge vlan.
The idea behind is that each row of /interface bridge actually aggregates parameters for three distinct types of objects linked together:
  1. the bridge itself, as in "virtual switch"
  2. the virtual member port of that bridge, to which a virtual port of a virtual router is connected
  3. the virtual port of a virtual router, connected to the virtual switch
As there is a 1:1:1 relationship between those objects, they are referred to by a single common name, and the actual relationship of the particular setting to a particular object is determined by context.
So
  • the pvid parameter on the /interface bridge row relates to the type 2 object (for other member ports of bridges, the pvid parameter is on the /interface bridge port rows)
  • on the /interface bridge vlan row, the bridge parameter refers to the type 1 objects, and the tagged and untagged lists contain type 2 objects and other member ports of bridges
  • on the /interface vlan, /ip dhcp-client, /ip address, /ip dhcp-server and some other less "popular" rows, the interface parameter refers to type 3 objects
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
samreiss
Thu Jan 14, 2021 10:34 pm
Thank you for the detailed response! That helps alot, but unfortunately I am not quite resolved. I am still not pulling an IP from the DHCP server assigned range when connecting via SSID (I don't even get an IP from DHCP when I am connected directly into the router with a cable). Any ideas? Below is the export with the changes you recommended.
# jan/02/1970 00:46:51 by RouterOS 6.43.7
/caps-man channel
    vlan-filtering=yes
/interface wireless
# channel: 2442/20-Ce/gn(28dBm), SSID: PRIVATE_CAP, local forwarding
/interface vlan
/caps-man datapath
/caps-man security
/ip hotspot profile
    dhcp-server-22-kids
/ppp profile
/caps-man manager
set enabled=yes
add bridge=bridge tagged=bridge untagged=ether3 vlan-ids=21
add bridge=bridge tagged=bridge untagged=ether2 vlan-ids=20
add bridge=bridge tagged=bridge vlan-ids=22
set enabled=yes
/ip cloud
/ip dhcp-client
    ether1
/ip dns static
    protocol=udp
    invalid
    192.168.89.0/24
/ppp secret
add name=vpn
/system identity
set name=BASEMENT
/tool mac-server
sindy
Thu Jan 14, 2021 10:46 pm
Cannot spot anything. What does /interface bridge vlan print show?
samreiss
Thu Jan 14, 2021 11:03 pm
[admin@BASEMENT] > /interface bridge vlan print
Flags: X - disabled, D - dynamic
 #   BRIDGE           VLAN-IDS  CURRENT-TAGGED          CURRENT-UNTAGGED
 0   bridge           21        bridge
 1   bridge           20        bridge                  wlan2ghz
                                                        wlan5ghz
 2   bridge           22        bridge
 3 D bridge           1                                 bridge
                                                        ether4
sindy
Thu Jan 14, 2021 11:17 pm
Hm, it seems that the automatic addition of untagged ports to vlans based on their pvid, and automatic addition of caps-man interfaces, did not work yet in 6.43.7. What makes you stick with more than two years old release?
tdw
Long time Member
Long time Member
Fri Jan 15, 2021 12:14 am
As the wireless interfaces are managed by CAPsMAN they should not be manually added under /interface bridge port
samreiss
Fri Jan 15, 2021 7:16 am
I have updated to the latest version, but have the same issue. Any recommendations on how to tag the VLAN in CAPsMAN properly? I am able to get this working by bypassing CAPsMAN & setting the PVID on the wlan5ghz interface, but I don't want to do that with CAPsMAN because the WLANs are set dynamically.
sindy
Fri Jan 15, 2021 7:48 am
Again, I cannot see anything wrong in the configuration, the datapath settings are correct. As you don't get a lease even if you connect a wired client, it doesn't seem to be related to capsman.
After the upgrade (to what version?), what does /interface bridge vlan print show?
samreiss
Sat Jan 16, 2021 4:52 am
I was able to turn on CAPsMAN forwarding to get this to work. Unfortunately, I can't seem to get it working with local forwarding mode on CAPsMAN. Thank you for your help!
Users browsing this forum: anav, bandini981, DanMos79, edhunter, fzinfz, JSchwabe, leonardogyn, trens and 191 guests
