chrismal
css326 and rb4011 getting errors with 10G SFP+ uplink
Thu Jan 14, 2021 9:47 am
Hi, I got my switch uplinked via 10G DAC Active (DAC fs.com https://www.fs.com/de-en/products/74625 ... &id=147869 ) on the switch I keep getting these error Rx MAC Errors, Rx FCS Errors and Tx Pauses, switch firmware v 2.12.
Do SWOS have SFP+ bugs?
thanks,
regards
chrismal
Re: css326 and rb4011 getting errors with 10G SFP+ uplink
Fri Jan 15, 2021 9:24 pm
Anything?
Wolfraider
Fri Jan 15, 2021 10:06 pm
The RB4011 SFP+ port is a little weird. We have had much better luck using a couple of these and a patch cable https://www.fs.com/products/11556.html? ... &id=162909
chrismal
Sat Jan 16, 2021 4:04 pm
The problem looks to be solved by cleaning the DAC's SFP modules.
nescafe2002
Forum Veteran
Forum Veteran
Sat Jan 16, 2021 4:22 pm
Did you clean the connector or the optical side? And how?
chrismal
Sat Jan 16, 2021 4:54 pm
I cleaned the part that goes into the switch, not a great way to clean but I used a cotton cloth, will see if errors will show up, usually I get errors right away, but will see
chrismal
Sat Jan 16, 2021 5:57 pm
scrap that, 1Rx FCS Error came up, its just 1 but still not good
IPANetEngineer
Trainer
Trainer
Sat Jan 16, 2021 6:22 pm
There were problems with using the SFP+ port on the 4011 with DAC cables in the past. The issue has been fixed in RouterOS, but we still use optical connections on 4011s and have no issues.
I would change to optical and see if the FCS errors continue.
Global - MikroTik Support & Consulting - English | Español | Serbian | Danish +1 855-645-7684
https://iparchitechs.com/ecosystem/mikr ... consulting mikrotiksupport@iparchitechs.com
chrismal
Sat Jan 16, 2021 6:34 pm
Thanks for the suggestion, I will try that.
Users browsing this forum: dchepishev, jhbarrantes and 201 guests
