I have a problem using ssh-exec command.
I'm trying to remotely execute SSH command from a Mikrotik RB2011 router to an Aruba cisco switch.
I used the following commands line :
Code: Select all
/system ssh-exec address=172.16.1.250 command="configure terminal; no power-over-ethernet"
exit-code: 0
output: SSH command execution is not supported.
Does anyone have a solution to that ?
I was wondering that there is no difference between using ssh-execution commands from the Mikrotik routers and manually connect to SSH switch with putty.
Thanks,
