pachy
2.5G port hardware compatibility
Tue Feb 16, 2021 11:20 am
Hi, in france, an internet provider (free) provide Server with 2.5 Gb copper port. I have an hex S, i can choose 2.5Gb in Interface but i think MT7621 is only with1gb ports. I m looking for a mikrotik hardware with 2.5Gb ports, but there's nothing easy to find. I have looking for in the product_matrix files but nothing...
Do you have an idea for me ?
Regards
anav
Re: 2.5G port hardware compatibility
Tue Feb 16, 2021 3:45 pm
Hi there
Not sure if your intention is to cable with fiber to devices or use copper cages and transfer to ethernet cable.
How many devices do you have that can use SFP ports/speeds?
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
pachy
Tue Feb 16, 2021 3:48 pm
Hi thank you for your answer, I would like to plug only copper cables...
anav
Tue Feb 16, 2021 4:12 pm
That helps, also the cable from the ISP modem/ont to the Mikrotik, would this be copper or fiber cable?
pachy
Tue Feb 16, 2021 5:12 pm
Cable between isp box and MikroTik is copper, it s for this link I need 2.5G link...
mbovenka
Tue Feb 16, 2021 7:48 pm
Assuming you need a router, you need something with an SFP+ cage and use a copper SFP+ like the S+RJ10 in it. Cheapest option is a RB4011, cheapest with multiple ports is a CCR2004.
Switches with 10G copper ports will also do 2.5G.
pachy
Tue Feb 16, 2021 8:47 pm
Thank you for these solutions 👍
Users browsing this forum: Bing [Bot], nickrod50, silencedugu and 165 guests
