wispvt
Forward between subnets on Bridge
Thu Feb 18, 2021 3:34 am
I am trying to allow my VPN server where the clients are 10.0.80.0 and its LAN has an IP of 10.0.90.10 which is connected to a Mikrotik router which does NAT and has 10.0.90.1 assigned to its bridge. I am trying to allow the VPN clients to communicate to other clients that have ip addresses 10.0.90.x across the bridge. I created a static route in the Mikrotik with 10.0.80.0/24 via 10.0.90.10. The VPN clients can now connect with the Mikrotik but not other devices on the 10.0.90.x network on the bridge. So how do I get the forwarding to work between ports and subnets on the bridge.
vecernik87
Forum Veteran
Forum Veteran
Re: Forward between subnets on Bridge
Thu Feb 18, 2021 6:59 am
Without complete config of router as well as your VPN server it is not easy to solve. My, best wild guess would be that you need to add a firewall-forward rule. (But not to the end, somewhere before "forward - drop all" rule.)
If you are unsure or just want to test it, you can put it on top of all rules:
/ip firewall filter add action=accept chain=forward dst-address=10.0.90.0/24 src-address=10.0.80.0/24 place-before=0
Users browsing this forum: eworm, FezzFest, nickrod50 and 196 guests
