I want to used mAP lite as CPE to give a network connection to many wired devices (more than 380 devices in an industrial company).
The current configuration is simple as possible :
Code: Select all
add name=WAN
add name=LAN
add interface=wlan1 list=WAN
add interface=ether1 list=LAN
add interface=wlan1
add name=bridge1 protocol-mode=none
add bridge=bridge1 interface=wlan1
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no mode=station-pseudobridge security-profile="Wifi Password" ssid="XX"
add authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys name="Wifi Password" supplicant-identity=MikroTik wpa-pre-shared-key=XX wpa2-pre-shared-key=XX
add addresses=::/0 name=XX
add address=AA.BB.CC.DD/24 interface=ether1 network=AA.BB.CC.0
add dhcp-options=hostname,clientid interface=bridge1
set servers=XX,YY
add distance=1 gateway=ZZ
set name=XX
But with this "bridge", I can't connect to the "linked" wired devices. The ARP table of my router contain the same mac address two times...Below a simple diagram of my current configuration :
What is the configuration I need to correct this issues ?
Jerome
