DarkNate
Site-to-Site VPN (3 MikroTik routers)
Fri Mar 19, 2021 9:45 am
Link to Reddit thread: https://www.reddit.com/r/mikrotik/comme ... k_routers/
So an ISP wants me to set up a secure site-to-site VPN between A, B, C and ensuring redundancy such that A can reach C if B is down and so on.
Their Diagram
Router A, B, C all have public IP of the same subnet/prefix
They want to set up site-to-site in order to for the internal network of A, B, C to be accessible by each and any of the sites. For example, those in A can access B, those in B can access C and C and access A etc.
So what would be the optimal solution for this? Which VPN protocol can ensure good performance along with redundancy? I've looked at MikroTik docs/guides/forums but most of them only talk about IPSec with two sites.
I would definitely need some implementation examples/help on this one.
gotsprings
Re: Site-to-Site VPN (3 MikroTik routers)
Fri Mar 19, 2021 12:12 pm
If you use the typical IPSec one... You can add a 3rd site pretty easily.
accarda
Fri Mar 19, 2021 12:31 pm
You can also check this example viewtopic.php?f=23&t=169538 that explains how to use IKE2 with 3 sites.
anav
Fri Mar 19, 2021 12:35 pm
Not knowing the complex subject, I can only ask.......
Would it make sense to use MT proprietary Eoip tunneling and create a common network, or is that functionality only useful in a two site scenario??
https://help.mikrotik.com/docs/display/ROS/EoIP
DarkNate
Re: Site-to-Site VPN (3 MikroTik routers)  [SOLVED]
Sat Mar 20, 2021 7:01 am
Thread solved. IPIP tunnel + IPSec.
predescum
Sun Mar 28, 2021 11:55 am
Hello i try to make a ipip tunel behind a router, which is the ipip port to fw ?
Users browsing this forum: Amaan, baragoon, jason9456402 and 160 guests
