OpenFiber
hAP AC3: SIM not inserted
Wed Mar 24, 2021 10:24 am
Just tried to configure a brand new hAP AC3 LTE to function as a LTE / 4G router.
But the hAP AC3 keeps saying "SIM not inserted".
The SIM works perfectly in an iPhone and has worked in another hAP AC3 LTE before.
The device is running 6.48.1 (both packages and routerboard firmware)
Also tried 6.49beta27, same results.
Any thoughts?
normis
Re: hAP AC3: SIM not inserted
Wed Mar 24, 2021 12:39 pm
Well try to remove it and insert it again a few times. Also check that it's not upside down. The error means what it says.
SiB
Thu Mar 25, 2021 2:26 am
Please connect to that unit any internet to ether1 and when unit have internet then try upgrade lte module firmware:
https://wiki.mikrotik.com/wiki/Manual:I ... re_upgrade
This helps some people.
Others use a isopropyl alcohol at contacts of sim and this fix connection.
Some others person tape office transparent tape at back of sim and then it's start be working fine (special some revision of lhgr).
OpenFiber
Thu Mar 25, 2021 5:07 pm
Hi guys thanks for the advices!
It turned out to be a physical issue with the SIM-card connector pins, not all pins actually had contact with the inserted SIM-card.
We've bended the problematic pins and it instantly worked!
Thanks again!
Users browsing this forum: 4l4R1, ips and 101 guests
