Port 1-4 = Trunk Port
Port 5 = Access Port (VL10)
set 0 vlan-mode=secure
set 1 vlan-mode=secure
set 2 vlan-mode=secure
set 3 vlan-mode=secure
set 4 default-vlan-id=10 vlan-header=always-strip vlan-mode=secure
set 5 vlan-mode=secure
Is A or B correct: (or are they in effect the same, as eth5 is set to strip header above)
A:
add independent-learning=yes ports=ether1,ether2,ether3,ether4,ether5,switch1-cpu switch=switch1 vlan-id=1
add independent-learning=yes ports=ether1,ether2,ether3,ether4,ether5 switch=switch1 vlan-id=10
add independent-learning=yes ports=ether1,ether2,ether3,ether4,ether5 switch=switch1 vlan-id=20
B:
add independent-learning=yes ports=ether1,ether2,ether3,ether4,switch1-cpu switch=switch1 vlan-id=1
add independent-learning=yes ports=ether1,ether2,ether3,ether4 switch=switch1 vlan-id=20
