Mike33
Setting the distance for the l2tp connection route
Fri Mar 26, 2021 2:34 pm
There is a client l2tp connection.
This connection adds a default route.
How to make this route have a distance greater than 1?
This connection is a backup and it is necessary that it route traffic through itself only when the main connection (which is via ethernet) drops.
nickshore
Long time Member
Long time Member
Re: Setting the distance for the l2tp connection route  [SOLVED]
Fri Mar 26, 2021 2:47 pm
You can specify it when you create the l2tp-client:
 /interface l2tp-client add add-default-route=yes default-route-distance=10
Mike33
Fri Mar 26, 2021 2:51 pm
Many thanks!!!
Users browsing this forum: artone, eworm, K0NCTANT1N, morgot999, taksa and 106 guests
