Cablenut9
Long time Member
Long time Member
Way to set the NAT type?
Wed Apr 14, 2021 6:56 am
It'd be nice to be able to change the masquerade NAT rule to be one of the many kinds of NAT available: full cone, port/address restricted cone, or symmetric. Is this possible?
pe1chl
Re: Way to set the NAT type?
Wed Apr 14, 2021 11:55 am
No. But you can write individual srcnat rules that can do almost anything you would want.
anav
Wed Apr 14, 2021 3:52 pm
What is the advantage of being able to set different types of NAT.
I have not run across the need for such dexterity?
Also can you give an example of how sourcenat accomplishes the same thing as cone nat or restricted etc......... (given a practical example by the OP for example).
Cablenut9
Long time Member
Long time Member
Wed Apr 14, 2021 5:30 pm
Sometimes you need to do something very specific that requires a special feature, and it's also a selling point compared to other network OSes like IOS.
mkx
Wed Apr 14, 2021 5:48 pm
If I understand things correctly (and very likely I don't), these terms really apply fully when one has multiple public addresses. In that case there are ways to acomplish target manually or semi-automatically under ROS.
If one only has single public address (usual situation for home users), then these terms are simply buzzwords without any meaning.
lufer
Wed Apr 14, 2021 5:58 pm
Not directly, but you can create srcnat rules that will do the same althought im not sure to understand the question correctly.
Users browsing this forum: CHUPAPEE, faxxe, holla29 and 208 guests
