I'm needing to do the following
Port 1 - WAN
Port 2 - LAN on 192.168.2.1 with DHCP disabled, using the WAN
Port 3 - LAN on 192.168.3.1 with DHCP enabled, using the WAN
Port 4 - LAN on 192.168.4.1 with DHCP enabled, using the WAN
Port 5 - LAN on 192.168.5.1 with DHCP enabled, using the WAN
But I need these to not be able to communicate with each other. All on their own networks. I found a few posts about how this model of router doesn't actually support VLANs, and I need to set up some sort of "software-based" VLANs? I'm not sure what that is. Could any one help me out?
