nostromog
Connection tracking problem with discovery
Sun Apr 18, 2021 6:45 pm
Hi, I see strange "new" connections coming from 159.148.147.229:30000 to my ip port 5678
This is probably due to discovery protocol interacting badly with connection tracking code. If I /tool/sniffer I can see request/response, but apparently, for the connection tracking machinery the request is not seen, and the response comes as a "new" connection.
Is it well known? Will it be fixed? For what I know happens in development, testing, stable and longterm.
mkx
Re: Connection tracking problem with discovery
Sun Apr 18, 2021 8:59 pm
TCP connection is considered "established" after successful completion of three-way handshake. If some remote host is probing a TCP port to check if it's open, it might send only initial packet and wait for reply - if reply is received, port is very likely open. Since port scanners are not interested in establishing connections, they generally skip the third step ...
If that is so, there's nothing to be fixed in ROS. You should consider closing that port to internet if it0s not really needed.
nostromog
Mon Apr 19, 2021 12:03 am
Maybe I was not completely clear: the 159.148.147.229:30000 belongs to mikrotik, I think it is about /interface/detect-internet , and the protocol is UDP, no three-way handshake.
For some reason, the initial packet (from the router to the mikrotik server) is ignored by the connection tracking machinery, and the response appears to the firewall as starting an incomming connection, with connection-state=new :
[user@Mikrotik] > /tool/sniffer/quick interface=ether1 ip-address=159.148.147.229
Columns: INTERFACE, TIME, NUM, DIR, SRC-MAC, DST-MAC, SRC-ADDRESS, DST-ADDRESS, PROTOCOL, SIZE, CPU, FP
  INTERF  TIME      NU  DI  SRC-MAC            DST-MAC            SRC-ADDRESS                    DST-ADDRESS                    PROTOC  SI  C  FP
  ether1  640.438   21  ->  CC:2D:E0:C3:9B:90  94:6A:B0:60:CA:B9  192.168.1.33:5678 (discovery)  159.148.147.229:30000          ip:udp  74  0  no
  ether1  640.516   22  <-  94:6A:B0:60:CA:B9  CC:2D:E0:C3:9B:90  159.148.147.229:30000          192.168.1.33:5678 (discovery)  ip:udp  74  0  no
  ether1  700.441   23  ->  CC:2D:E0:C3:9B:90  94:6A:B0:60:CA:B9  192.168.1.33:5678 (discovery)  159.148.147.229:30000          ip:udp  74  0  no
  ether1  700.516   24  <-  94:6A:B0:60:CA:B9  CC:2D:E0:C3:9B:90  159.148.147.229:30000          192.168.1.33:5678 (discovery)  ip:udp  74  0  no
mkx
Mon Apr 19, 2021 12:14 am
How exactly are these connections shown in connection tracking list?
nostromog
Mon May 03, 2021 9:44 am
I use "interval=1" to watch them appear and then quit before they timeout, and execute the line again. They appear every minute or so.
They used to appear because I have a droplist populated by new connection attempts, and when I started using it for UDP I started seeing mikortik and DNS addresses in it.
So, for some reason what the firewall sees is a connection attempt from google DNS to my machine :5678, or from Mikrotik's :30000
[admin@Mikrotik] /> /ip/firewall/connection/print detail interval=1 where protocol=udp dst-address~"NN.NN.NN.NN:"
Flags: E - expected; S - seen-reply; A - assured; C - confirmed; D - dying; F - fasttrack; H - hw-offload; s - srcnat; d - dstnat
12    C      protocol=udp src-address=8.8.8.8:53 dst-address=NN.NN.NN.NN:5678 reply-src-address=NN.NN.NN.NN:5678 reply-dst-address=8.8.8.8:53
             timeout=4s orig-packets=1 orig-bytes=80 orig-fasttrack-packets=0 orig-fasttrack-bytes=0 repl-packets=0 repl-bytes=0
             repl-fasttrack-packets=0 repl-fasttrack-bytes=0 orig-rate=0bps repl-rate=0bps
13    C      protocol=udp src-address=159.148.147.229:30000 dst-address=NN.NN.NN.NN:5678 reply-src-address=NN.NN.NN.NN:5678
             reply-dst-address=159.148.147.229:30000 timeout=9s orig-packets=1 orig-bytes=60 orig-fasttrack-packets=0 orig-fasttrack-bytes=0
             repl-packets=0 repl-bytes=0 repl-fasttrack-packets=0 repl-fasttrack-bytes=0 orig-rate=0bps repl-rate=0bps
Users browsing this forum: abbio90, alixviral, anav, jaclaz, VirtualEvan and 183 guests
