triggerhounds
Why I can't have a gigabit connection with rb750gr3
Fri Apr 23, 2021 3:48 pm
please see my attachment.
BergDev
Re: Why I can't have a gigabit connection with rb750gr3
Sat May 08, 2021 9:51 am
You can send it to the configuration topic /export hide-sensitive
rextended
Sat May 08, 2021 10:44 am
Probably the user have PC with 100Mbit ethernet and expect that this number, with 3 provider at 100Mbit/s grows up to 300...
Like others than use 300Mbps Access Point and have only 100Mbit/s from provider,
and still tink he have 300Mbit/s from provider because wireless link speed is 300Mbit/s...
BergDev
Sat May 08, 2021 10:46 am
Probably the user have PC with 100Mbit ethernet and do not know the differencies from link speed and ethernet speed...
Like others use 300Mbps Access Point and have only 100Mbit/s from provider, and still tink he have 300Mbit/s from provider because link speed is 300Mbit/s...
Most likely it is, although I have met in practice that the automatic detection of the port speed worked incorrectly.
rextended
Sat May 08, 2021 10:47 am
Ethernet type are not viewable on screenshot
The clue is on picture: "I SHOULD HAVE 300MBPS"... the user clearly do not know how the things works.
If I'm wrong, is because English or not, he explained really badly what is expecting.
And my English is really poor.
Znevna
Sat May 08, 2021 11:02 am
He posted that screenshot from a Windows machine with the Link Speed of 100Mbps, but didn't mention where that PC is plugged in.. those screenshots only have "ISP" Links and a "LAN" link between the routers..
Faulty cable? limited interface on the PC/Laptop of only 100Mbps? Wrong settings on one of the routers? Wrong settings on the PC/Laptop interface? all of these? none? something else?
Cosmic rays!
rextended
Sat May 08, 2021 11:03 am
Probably
anav
Sat May 08, 2021 3:28 pm
Based on the test results one should expect 700-800 WAN throughput on the hex, 900 is doing really well.
Users browsing this forum: bcmdevtl, shahzaddj1 and 84 guests
