JRJakkals
DDNS Port Forwarding RouterOS ver 6.48.1 not working
Thu Apr 29, 2021 1:01 pm
Hi Experts
I need help on port forwarding. I need to access to alarm system on public\website\app on port 10001. I have setup port forwarding\natting on Mikrotik and Mikrotik DDNS. Port forwarding not working, cant access ddns name on port number 10001. Works fine on LAN
WAN cronjehome.sn.mynetname.net:10001 = Not working
LAN 192.168.0.3:10001 = working
Network Diagram
Image[/url]
Image[/url]
Image[/url]
Config
# apr/29/2021 11:24:39 by RouterOS 6.48.1
# software id = KQAL-TRIU
# model = RB941-2nD
# serial number =
add admin-mac=C4:AD:34:F4:4F:1A auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-b/g/n channel-width=\
20/40mhz-XX country="south africa" disabled=no distance=indoors \
frequency=auto frequency-mode=manual-txpower installation=indoor mode=\
ap-bridge ssid=CronjeWireless station-roaming=enabled wireless-protocol=\
802.11
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
password= service-name=Vodacom user=
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=\
wpa2-pre-shared-key=
add name=dhcp ranges=192.168.0.10-192.168.0.254
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge comment=defconf interface=pwr-line1
/interface l2tp-server server
set enabled=yes ipsec-secret= use-ipsec=yes
#error exporting /interface ovpn-server server
#interrupted
Firewall\natting
# apr/29/2021 11:29:26 by RouterOS 6.48.1
# model = RB941-2nD
# serial number =
established,related,untracked
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
invalid
in-interface-list=!LAN
add action=accept chain=forward dst-address=192.168.0.3 dst-port=10001 \
in-interface=ether1 protocol=tcp
add action=accept chain=forward dst-address=192.168.0.3 dst-port=10000 \
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=dst-nat chain=dstnat dst-port=10000 in-interface=ether1 protocol=\
tcp to-addresses=192.168.0.3 to-ports=10000
udp to-addresses=192.168.0.3 to-ports=10000
add action=dst-nat chain=dstnat dst-port=10001 in-interface=ether1 protocol=\
udp to-addresses=192.168.0.3 to-ports=10001
tcp to-addresses=192.168.0.3 to-ports=10001
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
192.168.89.0/24
erlinden
Re: Port Forwarding ver 6.48.1
Thu Apr 29, 2021 1:10 pm
Are you really really really sure you want your alarm directly available through the Internet!?
Can you connect/test on the LAN?
What is the exact problem you are running into?
Instead of using ether1, shouldn't you be using the pppoe interface for the forward?
JRJakkals
Thu Apr 29, 2021 1:12 pm
Yes I can access alarm on Lan and yes I want to access alarm from external.
JRJakkals
Thu Apr 29, 2021 1:27 pm
Port forwarding not working.
anav
Re: DDNS Port Forwarding ver 6.48.1  [SOLVED]
Thu Apr 29, 2021 1:41 pm
Okay, good to know, because many times people try to reach the server from behind the router using the public IP (vice the LANIP) and thats a loopback scenario that requires extra nat rules.
However you are clearly indicating a valid external access attempt.
(1) These rules do not belong in the forward chain as they are NAT type rules, so they should be removed.
(2) This default firewall rule in the forward chain is in place which is GOOD because this is the only firewall rule you need to allow destination natted packets to get to the LAN.
(3) FInally change all your ether1 entries to in-interface-list=WAN (or in-interface=pppoe-out1)
JRJakkals
Re: DDNS Port Forwarding RouterOS ver 6.48.1 not working
Thu Apr 29, 2021 1:55 pm
Thank you very much anav
Its working now. I have been watching your post and you are really good. You should start charging a fee and do remote support. Or start creating a youtube channel
Kind Regards
rextended
Thu Apr 29, 2021 2:03 pm
Kind Regards
If do that, probably do not help you on this forum... ;)
anav
Thu Apr 29, 2021 4:34 pm
Kind words, but I am no expert!! All my knowledge has been from picking the brains of the real experts here.
They know who they are LOL.
My goal is to bridge the gap between home owners and the expert advice that assumes way to much knowledge and cannot relate to ordinary people LOL.
Users browsing this forum: mostfa228, MrRey and 106 guests
