anav
VPN OPTIONS @ HELP with MUDI
Thu Apr 29, 2021 10:39 pm
What is MUDI you say
https://www.gl-inet.com/products/gl-e750/#specs
My challenge is to connect the MUDI (either this units' embedded wireguard or open vpn client) to my CCR1009 as the VPN server.
The intent is to create a tunnel whereby the far end client goes out the internet via my internet account (public IP).
Is this possible or a waste of time (if the CCR1009 aka ROS is not capable of acting as an OPEN VPN or Wireguard Server)??
[note: if not possible I have a spare hex that I will use instead. the hex would unfortunately be a router behind the combined modem/router of the provider (bell). The intent here would be to setup a secure enough tunnel for the client simply to use my internet, could be EOIP if thats all that is needed or a full blown IPSEC VPN if thats better. Easiest being the key word.]
Zacharias
Re: VPN OPTIONS @ HELP with MUDI
Fri Apr 30, 2021 12:39 am
Looks nice...
There is no wireguard support as far as i know...
joegoldman
Forum Veteran
Forum Veteran
Fri Apr 30, 2021 2:31 am
Mikrotik supports OVPN server - but only supports certain parts of the spec, so you'll need to read through both documentations to get configuration right.
anav
Fri Apr 30, 2021 4:41 am
Kk thanks,
Users browsing this forum: Ahrefs [Bot], courtois, GoogleOther [Bot] and 94 guests
