MUM Europe 2020
jacoblydon
Default Authentication option
Thu Aug 02, 2007 12:11 am
I have one AP that I tried this on. I hide the SSID and try and apply the default authentication.
I have also saved my clients to an access list. When I try to un check default authentication it will save, but only one or two of my clients will register. I have approximately 12 clients on this AP. I have used these same steps on several other AP's and it works fine. Any suggestions?
sergejs
Re: Default Authentication option
Thu Aug 02, 2007 7:45 am
Check for the correct configuration on 'access-list' (make sure that all options match client settings), make sure you are running the latest version.
jacoblydon
Fri Aug 03, 2007 7:07 pm
Thanks, Sergejs, You were my instructor in Florida.
Users browsing this forum: BonDyaRa, ipfw, JRLL and 107 guests
