ICNIT
Different Interface to difference WAN
Mon May 17, 2021 9:38 am
Hi All,
I think it sounds stupid, but I just want to double confirm.
Scenario Ether1=WAN1 , Ether2=WAN2 , Ether3,4,5=Bridge (VLAN1,VLAN10,VLAN20,VLAN30).
If I want VLAN1 user to use WAN1, and VLAN10,20,30 to use WAN2, is it possible to be done in firewall > NAT?
Chain: scr-nat
Src. address: 172.16.0.0/24 (VLAN1)
Out. Interface: WAN1
Action: masquerade
Chain: scr-nat
Src. address: 172.16.10.0/24, 172.16.20.0/24, 172.16.30.0/24(VLAN10,20,30)
Out. Interface: WAN2
Action: masquerade
So user in VLAN1 doesnt share the bandwidth with user in VLAN10,20,30.
Is it possible to work?
Thanks.
rextended
Re: Different Interface to difference WAN
Mon May 17, 2021 12:21 pm
yes, can
sid5632
Long time Member
Long time Member
Mon May 17, 2021 2:16 pm
By double-posting in two different forum sections?
anav
Mon May 17, 2021 2:21 pm
Using firewall rules for routing is not the preferred path because that is not what they are designed/responsible to do.
What firewall rules are intended to do is to ensure you either allow or deny traffic between networks, subnets or devices, in terms of access to/fro the router or across the router.
For example in firewall rules you can say vlan10 you are allowed out wan1 and vlan10 you are not allowed out WAN2 but that doesnt tell VLAN10 where to attempt to go out of the router.
That is done by routes and is where you should delineate where subnets traffic is to BE DIRECTED if that is the requirement.
Firewall rule = where traffic is permitted/denied
Route = where traffic is sent/directed
I hope that makes it clearer, albeit a shitty explanation.
By the way do not use vlan1, it is the default vlan to be used with bridges, for example, and thus shouldnt be used for normal vlan traffic.
This article is the best on vlans.....
viewtopic.php?f=23&t=143620
In terms of Routes
Its hard to provide advice as we do not see your current route setup.
/export hide-sensitive file=anynameyouwish.
Typically one has
0.0.0.0/0 gwy of ISP1=x.x.x.x check-gateway=ping distance=5
0.0.0.0/0 gwy of ISP2=y.y.y.y distance=10
Where ISP1 is the primary and if it goes down then the router switches to ISP1.
In this case ISP2 is not used at all except for a backup scenario.
Lets say you have vlans 10,20.30 and 31 and you wanted all of them to use WAN1 except vlan 31
Then the only change required would be the following:
0.0.0.0/0 gwy of ISP2=y.y.y.y distance=10 routing-mark=wan2-only
Where in your setup you add a second instance of the WAN2 route but add a routing mark and then fill in an associated route rule, with the command of lookup only in table.
As per the diagram, which in effect will take any internet bound traffic for my vlan31 and send it out on WAN2, all the time.
rextended
Mon May 17, 2021 2:33 pm
also do routing for private IP (172.16.0.0....172.31.255.255) on the Internet without masquerading?
anav
Tue May 18, 2021 12:50 am
Not sure what you are getting at but one can have the standard source-nat rule in place or two standard rules which I prefer
Two rules for sourcenat
add action=masquerade chain=srcnat comment="SCR_NAT FOR WAN1" \
ipsec-policy=out,none out-interface=wan1interface
add action=masquerade chain=srcnat comment="SCR_NAT for WAN2" \
ipsec-policy=out,none out-interface=wan2interface
Singe rule for sourcenat
add action=masquerade chain=srcnat comment="SCR_NAT FOR BOTH WANS" \
where the interface list members would include
interface=wan1 list=WAN
interface=wan2 list=WAN
note: i dont stipulate the etherport in the above rules (single or dual), as if one uses pppoe or a vlan, that is what is required and same goes for list members. I always put the etherport as well for completeness on the interface list members.
rextended
Tue May 18, 2021 12:57 am
I really think that the misunderstand arose on the fact than I have to imagine the configuration,
because without seeing any graphics or /export, only the imagination remains...
anav
Tue May 18, 2021 1:07 am
Yes, best not to speculate and ask for network diagram and /export config...............
I simply went by his first line, and question which seemed like a routing question to me and something I dont use firewalls for as a direct approach
ICNIT
Tue May 18, 2021 3:52 am
so sorry, i didnt know i posted twice, because when i post this it gave me an error, then i went to another to post again.
first time here to post thread.
ICNIT
Tue May 18, 2021 4:03 am
In terms of Routes
Typically one has
sorry im still new in mikrotik and networking.
here is my configuration, its just a very simple config.
what i ask the original question is because my client have 2 x 1Gbps WAN with static public IP.
they want to make use of these 2 x 1Gbps to become 2Gbps bandwidth.
I done bonding before, but it doesnt work, ISP site doesnt create bonding at their end for us also.
We request ISP to create bonding at their end, but they replied me suggest to use BGP.
What is google BGP is normally use for ISP but not normal end user like us.
Thats why this scenario came in in my mind, why not I split different network to use different WAN.
anav
Tue May 18, 2021 4:18 am
Yes for bonding to work I believe the ISP has also to do their bit at their end.
I am not familiar with BGP but others here may be.
https://help.mikrotik.com/docs/pages/vi ... eId=328220
ICNIT
Tue May 18, 2021 4:41 am
but ISP doesnt allow or they lazy to do that.
i have a doubt, is load balance will make the bandwidth increase? cant right?
anav
Tue May 18, 2021 12:58 pm
Correct, one person will not be able to access 2gig in on session. The most any one session will be able to utilize is 1gig.
However you have more bandwidth to distribute to the users.
Users browsing this forum: mkx, Semrush [Bot], unhuzpt and 58 guests
