Hey guys,
Currently using Mikrotik CCR -1016-12G router and have encountered an issue with accessing Webfig from internally.
No configuration has been changed but the webfig page will no longer load, have attempted to access from different devices on multiple subnets/ports all with the same result of the web page endlessly loading. Are able to ping the interface ip's successfully (same ip as trying to access webfig) for many ports as well. Strangely enough, we are able to successfully connect via Winbox port 8291. All other router functions are working fine.
Has this issue ever been encountered before? Is there a possible fix besides a router reboot? A reboot would be a highly undesirable outcome and require careful planning. Any advice appreciated.
