Spaider
LHG LTE Kit: no internet on LAN. It's OK on router.
Sat May 29, 2021 12:33 am
Just bought LHG LTE Kit and I must admit I see a very strange problem. Connected everything, applied default configuration and figured that there's no Internet on LAN (ether1).
Here are some details:
  • Everything seems to be OK with access to Internet from router itself. I successfully upgraded to RouterOS 6.48.3 and upgraded LTE modem firmware
  • For testing purposes connected laptop to ethernet port. DHCP works fine, it obtained valid IP address
  • DNS works fine. I can successfully use nslookup, dig, ping by domain name
  • Browsers timed out. In general, seems to be a problem with TCP connections. I can see a lot of connections hanging in SYN SENT state.
Looks like NAT problem but I've checked config against my home router, which is also MikroTik. No differences and this is not a surprise because all I did is set it up using Quick Set.
Here's my config (I enabled Bridge in Quick set and set MTU to 1450 because this is the max size when ping packets able to come through without fragmentation):
[admin@MikroTik] > /export compact hide-sensitive
# may/29/2021 00:29:33 by RouterOS 6.48.3
# software id = RBT8-H6YA
# model = RBLHGR
/interface lte
set [ find ] allow-roaming=no name=lte1
add arp=local-proxy-arp mtu=1450 name=bridge1
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge1 name=defconf
add comment=defconf interface=ether1 list=LAN
add comment=defconf interface=lte1 list=WAN
add address=192.168.88.1/24 comment=defconf interface=bridge1 network=192.168.88.0
/ip dhcp-client
add
add address=0.0.0.0/24 comment=defconf gateway=0.0.0.0 netmask=24
add address=192.168.88.0/24 gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new \
    in-interface-list=WAN
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface-list=!LAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none log-prefix=nat out-interface-list=WAN
/system clock
set time-zone-name=Europe/Minsk
/tool mac-server
/tool mac-server mac-winbox
/tool sms
set port=lte1 receive-enabled=yes
Any clues are much appreciated :)
Spaider
Re: LHG LTE Kit: no internet on LAN. It's OK on router.
Sat May 29, 2021 1:34 pm
To answer my own question: problem was in provider blocking internet sharing. Fixed by playing with TTL.
SiB
Sun May 30, 2021 3:29 pm
congratulation. you can mark your own answer as SOLVED :)
jmri25
Tue Jun 15, 2021 12:44 am
Hi there friend! Can you decribe how to do this. We are having the same issue with a deployment.
Thanks in advance buddy.
Regards!
SiB
Sat Jul 03, 2021 5:41 pm
jmri25 write:
Easy, read a LTE manual with change TTL part: https://wiki.mikrotik.com/wiki/Manual:I ... throttling
Users browsing this forum: Amazon [Bot], ashraf993, Google [Bot], GoogleOther [Bot] and 84 guests
