wuffzack
DHCP server lease-script is not called on renew
Mon May 31, 2021 4:33 pm
Hello, I am running RouterOS 6.48.3 on CCR1009
I have a DHCP server running with a lease script.
From a Windows client cmd prompt, if I execute
ipconfig /release
ipconfig /renew
the script is executed twice. First with $leaseBound set to 0, then with $leaseBound set to 1, as expected. All is well.
However, if I execute only the renew on the Windows client
ipconfig /renew
the script is not called at all. I can see in the DHCP leases, that the lease expiration time of the Windows client was reset, so it did talk to the DHCP server and said "hello...".
Same thing happens, if I reboot the Windows client. Expiration date is reset, lease script is not called.
So here is the question: Is this expected behavior, or is this a bug in RouterOS, which I should report?
Or is there some option, where I can ask RouterOS to execute the script on a renew?
This would be a simple lease-script used for testing:
:log info message="$leaseBound $leaseServerName: $leaseActMAC -> $leaseActIP"
Thank you.
EDIT:
I forgot to mention, the Windows client has a static lease. Not sure, if this makes any difference.
rextended
Re: DHCP server lease-script is not called on renew
Mon May 31, 2021 4:44 pm
static, or not, not mind
renew = the same confirmed, the lease is not created or deleted, as expected nothing change, except "lifetime"
release = end-of-use, the lease will be dropped and this trig the event
all exactly what is expected.
wuffzack
Mon May 31, 2021 5:14 pm
Good to know, thank you!
Users browsing this forum: Google [Bot] and 74 guests
