jgauthier
Bridge not getting IP address.
Wed Jun 02, 2021 4:13 am
Greetings,
I have a RouterBOARD wAP G-5HacT2HnD, and I am trying to add it to CAPsMAN
Following these instructions:
https://wiki.mikrotik.com/wiki/Manual:S ... sMAN_setup
When I tried to create a bridge, I never get an IP address from DHCP.
add name=bridge
add bridge=bridge interface=ether1
/ip dhcp-client
add disabled=no interface=bridge
When I assign the DHCP client to ether1, I get an IP.
I didn't think a bridge was strictly needed, but since the wlan1/wlan2 won't register with CAPsMAN I wanted to go down that route.
anav
Re: Bridge not getting IP address.
Wed Jun 02, 2021 5:28 am
Draw a labelled network diagram your explanation is not clear.
jgauthier
Wed Jun 02, 2021 1:53 pm
A network diagram with 2 devices doesn't make sense.
I created a bridge on my RouterBOARD wAP G-5HacT2HnD.
add name=bridge
/ip dhcp-client
It doesn't get an IP address from DHCP.
If I assign a DHCP client to ether1, it gets an IP address.
That's the problem I am trying to solve. There's really no more to it (until there is)
erlinden
Wed Jun 02, 2021 2:00 pm
Easiest steps to follow:
https://wiki.mikrotik.com/wiki/Manual:R ... set_button
(and follow "Enabling CAPs mode" description)
biomesh
Long time Member
Long time Member
Wed Jun 02, 2021 2:02 pm
Please post your full config from the device.
anav
Wed Jun 02, 2021 2:07 pm
If you have only two devices why are you using capsman?
jgauthier
Wed Jun 02, 2021 4:00 pm
Well, I have more. However, I'm only setting up one at a time. Right now it's just a WAP router. Connected itself to capman.
Then I will start up the APs. This is my first AP. Hopefully, once it's working I can export and import the config.
jgauthier
Wed Jun 02, 2021 4:02 pm
I have seen that. But I wasn't a big fan of removing a plate and pushing a button for 5s every time I decided to reboot an AP. Or bring the home network down after a power failure, etc.
[edit] Oh, I guess once it's in caps mode it stays that way. I will experiment with this.
Users browsing this forum: Ahrefs [Bot], VirtualEvan and 139 guests
