zippoalice
some snmp oid timeout
Mon Jun 07, 2021 12:59 pm
Good morning,
I'm trying to use zabbix with mikrotik to monitor some remote rb via snmp
zabbix is ​​installed on a remote vps and I try to connect to the customers' rb through public ip (customers have wisp connection with cambium force 180/200 antennas which also act as nat) through portmapping of port 161 (10161 public and 161 private on ip of the rb)
I find myself this problem:
some oids do not respond (they time out both via zabbix and snmpwalk)
if I try to connect through a vpn instead they work correctly)
it looks like it's 64bit oid, while 32bit works but I'm not sure
for example:
Received Octets:
1.3.6.1.2.1.31.1.1.1.6 (ifHCInOctets, 64-bit version) times out
1.3.6.1.2.1.2.2.1.10 (ifInOctets, 32-bit version) works
Transmitted Octets:
1.3.6.1.2.1.31.1.1.1.10 (ifHCOutOctets, 64-bit version) times out
1.3.6.1.2.1.2.2.1.16 (ifOutOctets, 32-bit version) works
in your opinion, what could cause the problem?
good day everyone
Users browsing this forum: Amazon [Bot], GoogleOther [Bot], r0nzzibb and 217 guests
