GiovanniG
Can't enable both 2.4 and 5GHz with CAPS
Tue Jun 08, 2021 1:11 pm
HI, that's a strange problem, configuration is done, both frequencies work with CAPS but not together,
when I press the CAP putton under wireless interface it impose me to choose which interface, and I can't select both of them. Conseguentely I can see on CAPSman only the 2.4 (if I choose wlan1) or 5GHz, and on my phone as well the SSID corresponding. Why I have this problem?
This is a RBD52G-5HacD2HnD with 6.47.10
GiovanniG
Re: Can't enable both 2.4 and 5GHz with CAPS
Tue Jun 08, 2021 1:17 pm
Another question, configuring CAPSman on 5GHz ch there are much less parameters available than configuring it directly on AP.
erlinden
Tue Jun 08, 2021 1:19 pm
Did you configure the CAP manually to become a CAP?
Instead of using (tiny) screenshots, can you please post the /export of the CAP?
Regarding the parameters...that is correct. But...which one are you (really) missing?
prawira
Trainer
Trainer
Wed Jun 09, 2021 5:20 am
try this on console
/interface wireless cap set discovery-interfaces=ether1 enabled=yes interfaces=wlan1,wlan2
capsman dedicated for indoor enterprise wireless, so no options for station, station-bridge, nv2, nstream, wds, etc. the other setting are the same.
rextended
Wed Jun 09, 2021 12:38 pm
Non si vede un cazzo nello screenshot, va "interpretato"
con le freccette in fondo dove si seleziona l'interfaccia wlan1 si possono aggiungere altre righe per mettere anche la seconda interfaccia
rextended
Wed Jun 09, 2021 12:39 pm
E' normale, i parametri sono distribuiti tra tutte le schede del cap
Users browsing this forum: BoraHorza, holla29, jaclaz, JeffreyAxori, markinhusxp and 204 guests
