jgauthier
Trying to add a wireless VLAN (CAPsMAN)
Sun Jun 20, 2021 10:43 pm
I'm trying to add a VLAN to segregate an SSID. I thought it would be pretty straight forward, and I'v done plenty of work with VLANs in the past (but not router OS), But I can't seem to get it to "work".
Steps I've taken:
Added a VLAN interface (named it alexa) and attached it to the bridge. (The bridge is basically ether2-ether5, local LAN traffic)
 /interface vlan print
 #   NAME        MTU ARP             VLAN-ID INTERFACE
 0 R alexa        1500 enabled              90 bridge
Assigned an IP address to the VLAN:
 /ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   ;;; defconf
     192.168.80.1/24    192.168.80.0    bridge
 2   192.168.90.1/32    192.168.90.1    alexa
Added a DHCP pool for the VLAN:
 /ip pool print
 # NAME        RANGES
 0 default-dhcp        192.168.80.50-192.168.80.254
 1 alex_pool        192.168.90.50-192.168.90.254
The assigned IP address, 192.168.90.1, is up and active.
Added a datapath in CAPsMAN:
 /caps-man datapath print
 0 name="datapath1" bridge=bridge local-forwarding=no
 1 name="alexa_datapath" bridge=bridge local-forwarding=no vlan-mode=use-tag vlan-id=90
Then I added a new configuration in CAPsMAN and assigned it to the datapath.
(Omitted config)
The SSID shows up, and I can connect to it. However, no IP address is assigned from DHCP. So, I must be missing a configuration, or an option somewhere.
mducharme
Trainer
Trainer
Re: Trying to add a wireless VLAN (CAPsMAN)
Sun Jun 20, 2021 10:47 pm
You don't only need an ip pool - you also need a DHCP server and DHCP network for DHCP to work. Under IP->DHCP server, there is a DHCP Setup button that is basically a wizard that can create the server, the network, and the pool in one fell swoop - that is the easiest way to set up DHCP.
jgauthier
Sun Jun 20, 2021 10:52 pm
Great! I knew I missed something. That definitely got me an IP address! Now I will see if there are networking issues/firewall masq things I need to do.
Thanks for the close eye.
Users browsing this forum: AndersMogensen, complexxL9, nonolk and 35 guests
