Yochiro
Mikrotik Chateau LTE12 External Antenna problems
Tue Jun 29, 2021 6:09 pm
I work for an Operator Company and we use Mikrotik Chateau LTE12 for 4G network. I meant to put external antennas on this Mikrotik to increase the throughput, but unfortunatly, i found a problem. My external antenna are not detected by the mikrotik even through they are great linked. The external antenna is a mANT LTE 5o.
Antenna to chateau
ANT1 to ANT1
ANT2 to ANT4
In Interface > LTE > Antenna Scan → none
Furthermore, while looking through a solutions on forums and manuels, an option is not on my RouterOS which is on others in the forums. In Interface > LTE > Modem > External Antenna () ||
It mean i can’t select any external Antenna. I’ve tried with an other fresh new Mikrotik and mANT LTE 5o.
Can you help find a solution ?
In the attachment, i upload a picture of my RouterOS screenshot and a picture of my Router Chateau.
Thanks !
Yochiro
Re: Mikrotik Chateau LTE12 External Antenna problems
Wed Jun 30, 2021 10:51 am
Noone also have this problem ?
emilst
Wed Jun 30, 2021 11:34 am
What RouterOS version is the router on?
Are you able to switch to the external antennas with the CLI command?
/interface/lte/settings/set external-antenna=both
Yochiro
Wed Jun 30, 2021 12:47 pm
Hello, thanks for reply
The router is on v7.1beta5 (arm), it's the factory firmware.
Yes, it work with the CLI commands. And with a print :
/interface/lte/settings/print
mode: auto
firmware-path: firmware
external-antenna: both
But when i scan Antenna it still doesnt find the Antenna and the button in the graphic is still not shown.
Thanks for helping
rextended
Wed Jun 30, 2021 4:55 pm
The factory firmware of Chateau LTE12 [RBD53G-5HacD2HnD-TC&EG12-EA] is one dedicated version 7.0 not available to download directly.
Someone put a beta on the device.
emilst
Thu Jul 01, 2021 8:56 am
Please enable lte debug logging and send the supout.rif file from your device to support@mikrotik.com generated after running the antenna scan.
LTE debug logging can be enabled from CLI by issuing this command:
/system logging add topics=lte
This article explains how to make a supout.rif file:
https://wiki.mikrotik.com/wiki/Manual:S ... utput_File
BillyVan
Wed Jul 21, 2021 10:32 am
same problem here
i wrote about it
viewtopic.php?t=162363#p867038
temp solution
try from quick setup
rextended
Wed Jul 21, 2021 10:36 am
same problem here
RouterOS version?
You use the 7.0.3?
BillyVan
Wed Jul 21, 2021 2:22 pm
same problem here
RouterOS version?
You use the 7.0.3?
No i am using 7.1beta6.
Even with stable version same results (no ext ant)
From quick set its ok.
i have 3 chateau 12... only two of them have that problhm
by the way
see the photos
same model different name on winbox
on 2 with problem same name (D53G)
other one without problem (RBD53G)
Capture-2.jpg[/attachment ][attachment=1]Capture-1.jpg
check
rextended
Wed Jul 21, 2021 3:02 pm
What you mean for "stable version"?
You use exactly the 7.0.3 "non-beta" and the only firmware supported for that device?
BillyVan
Wed Jul 21, 2021 3:04 pm
viewtopic.php?f=1&t=175201#p865329
all devices comes with beta 7
rextended
Wed Jul 21, 2021 3:06 pm
BillyVan
Wed Jul 21, 2021 3:08 pm
OK i give a try tommorow
rextended
Wed Jul 21, 2021 3:09 pm
Very thanks!
BillyVan
Thu Jul 22, 2021 1:56 pm
The only dif before / after
/interface lte settings
set external-antenna=auto
in after file
rextended
Thu Jul 22, 2021 2:02 pm
Ok,
so it means that instead of using quickset, with the risk of accidentally changing configuration,
just simply paste this on the terminal:
Users browsing this forum: Ahrefs [Bot] and 176 guests
