Retral
HEX IPSec Connection Mark
Wed Jun 30, 2021 11:34 pm
I believe I may have found a bug in ROS 6.48.3
Does anyone else have the issue where if you have an IPSec peering setup between two Mikrotiks and then on the client end you set the respond only mode config connection mark and then can't see connection marks any where in connection tracking, nor can you catch any packets in any of the firewall chains?
-Edit, to clarify I am running the client end on a hEX RB750Gr3.
anav
Re: HEX IPSec Connection Mark
Thu Jul 01, 2021 12:36 am
Did you search the forum for the same issue using the search feature??
Did you need advice on how to submit a bug?
Users browsing this forum: Google [Bot], Guntis, neki and 104 guests
