Zoliace
Setup Mikrotik router this Security Defense than Juniper Router??
Tue Jul 06, 2021 2:36 pm
How Can I Setup Mikrotik router this Security Defense than Juniper Router?
This Juniper SSG 5 Security Tab
Flood Defense:
ICMP Flood Protection
Threshold
pps
UDP Flood Protection
Threshold
pps
SYN Flood Protection
Threshold
pps
Block HTTP Components:
Block Java Component
Block ActiveX Component
Block ZIP Component
Block EXE Component
Block Any Component
MS-Windows Defense
WinNuke Attack Protection
Scan/Spoof/Sweep Defense
IP Address Spoof Protection
IP Address Sweep Protection
Threshold
Microseconds
Port Scan Protection
Threshold
Microseconds
TCP Sweep Protection
Threshold
Packets Per Second
UDP Sweep Protection
Threshold
Packets Per Second
Denial of Service Defense
Ping of Death Attack Protection
Teardrop Attack Protection
ICMP Fragment Protection
ICMP Ping ID Zero Protection
Large Size ICMP Packet (Size > 1024) Protection
Block Fragment Traffic
Land Attack Protection
SYN-ACK-ACK Proxy Protection
Threshold
Connections
Source IP Based Session Limit
Threshold
Sessions
Destination IP Based Session Limit
Threshold
Sessions
Protocol Anomaly Reports -- IP Option Anomalies
Bad IP Option Protection
IP Timestamp Option Detection
IP Security Option Detection
IP Stream Option Detection
IP Record Route Option Detection
IP Loose Source Route Option Detection
IP Strict Source Route Option Detection
IP Source Route Option Filter
Protocol Anomaly Reports -- TCP/IP Anomalies
SYN Fragment Protection
TCP Packet Without Flag Protection
SYN and FIN Bits Set Protection
FIN Bit With No ACK Bit in Flags Protection
Unknown Protocol Protection
Finally:
How Can I Setup Malware defender than than Juniper Router?
thanks a lot,
Zoliace
anav
Re: Setup Mikrotik router this Security Defense than Juniper Router??
Tue Jul 06, 2021 4:15 pm
Assuming you want to replace an edge router for a large business?
My recommendation is to keep the juniper and use the MT for the internal router.
Zoliace
Tue Jul 06, 2021 4:52 pm
Tahks. but only i have mikrotik router. Another firm have Juniper router.
rextended
Tue Jul 06, 2021 4:58 pm
>useless, read ahead<
anav
Tue Jul 06, 2021 9:50 pm
if worried about emails use a barracuda device..........
https://www.barracuda.com/products/email_protection
rextended
Wed Jul 07, 2021 12:53 am
Thanks to your post, now I want update my post from 2014:
viewtopic.php?f=9&t=83387&p=417380
With all the possible defenses from various form of attack I find.
Now I check-lisk your post, and I modify THIS post removing what done on linked topic and leaving here what remain.
Checklist
Can do that:
Flood Defense:
"Done"
Block ZIP Component
Block EXE Component
Block Any Component
MikroTik can't do that (is not really full true, but do not make sense today with HTTPS)
Done
MS-Windows Defense
This is controversial, actually can be used as attack only for Windows 95 and Windows NT...
Is the time to change the machine 26 years old than protect it...
For paranoids this is the right rule:
/ip firewall raw
add action=drop chain=prerouting comment="WinNuke attack" dst-port=139 protocol=tcp tcp-flags=urg
Done IP Address Spoof Protection
Done Ping of Death Attack Protection
Done Teardrop Attack Protection
Done ICMP Fragment Protection
ICMP Ping ID Zero Protection NO, Mikrotik can't do that
Done Large Size ICMP Packet (Size > 1024) Protection
Done Block Fragment Traffic
Done Land Attack Protection
Can do that:
Can do that:
Done
Done
"Done"
How Can I Setup Malware defender than Juniper Router?
MikroTik can't do that.
Zoliace
Mon Jul 12, 2021 3:56 pm
Thanks!
I set up more of those listed.
rextended
Mon Jul 12, 2021 4:08 pm
What does it mean?
Users browsing this forum: akakua, Majestic-12 [Bot] and 128 guests
