NetEngMJ
Intermittent VLAN stripping on QCA8337 (RB3011UiAS-RM)
Mon Jul 12, 2021 10:33 am
Hi folks. I've noticed on at least one of my devices, I'm seeing very odd behavior regarding the QCA8337 switching functionality. Intermittently, traffic entering the MT router via one of the switch ports is not forwarded. It appears that the switch is intermittently entering a state in which it fails to apply the the proper 802.1q tag before passing the frame to the switch-cpu port. Even in this state, the issue only affects certain frames.
From laptop emitting ICMP pings via untagged frames connected directly to ether5 on the MT, I see the following via an MT capture (Packet Sniffer):
No.     Time           VLAN Source                Destination           Protocol Length Info
      1 0.000000            172.17.30.149         172.17.20.10          ICMP     98     Echo (ping) request  id=0x767a, seq=109/27904, ttl=64 (no response found!)
      2 5.001437            172.17.30.149         172.17.20.10          ICMP     98     Echo (ping) request  id=0x767a, seq=110/28160, ttl=64 (no response found!)
      3 5.887692       30   172.17.30.149         8.8.8.8               ICMP     102    Echo (ping) request  id=0xed7a, seq=0/0, ttl=64 (no response found!)
      4 6.887910       30   172.17.30.149         8.8.8.8               ICMP     102    Echo (ping) request  id=0xed7a, seq=1/256, ttl=64 (no response found!)
      5 7.891628       30   172.17.30.149         8.8.8.8               ICMP     102    Echo (ping) request  id=0xed7a, seq=2/512, ttl=64 (no response found!)
      6 8.896095       30   172.17.30.149         8.8.8.8               ICMP     102    Echo (ping) request  id=0xed7a, seq=3/768, ttl=64 (no response found!)
      7 9.900500       30   172.17.30.149         8.8.8.8               ICMP     102    Echo (ping) request  id=0xed7a, seq=4/1024, ttl=64 (no response found!)
      8 10.005374           172.17.30.149         172.17.20.10          ICMP     98     Echo (ping) request  id=0x767a, seq=111/28416, ttl=64 (no response found!)
      9 10.904655      30   172.17.30.149         8.8.8.8               ICMP     102    Echo (ping) request  id=0xed7a, seq=5/1280, ttl=64 (no response found!)
     10 15.005530           172.17.30.149         172.17.20.10          ICMP     98     Echo (ping) request  id=0x767a, seq=112/28672, ttl=64 (no response found!)
Note that the packets without 802.1q tags are the ones being dropped. This is confirmed by a similar capture on the vlan30 interface during that time:
      1 0.000000            172.17.30.149         8.8.8.8               ICMP     98     Echo (ping) request  id=0xf17a, seq=0/0, ttl=64 (reply in 2)
      2 0.006498            8.8.8.8               172.17.30.149         ICMP     98     Echo (ping) reply    id=0xf17a, seq=0/0, ttl=112 (request in 1)
      3 1.004280            172.17.30.149         8.8.8.8               ICMP     98     Echo (ping) request  id=0xf17a, seq=1/256, ttl=64 (reply in 4)
      4 1.010528            8.8.8.8               172.17.30.149         ICMP     98     Echo (ping) reply    id=0xf17a, seq=1/256, ttl=112 (request in 3)
      5 2.009309            172.17.30.149         8.8.8.8               ICMP     98     Echo (ping) request  id=0xf17a, seq=2/512, ttl=64 (reply in 6)
      6 2.015495            8.8.8.8               172.17.30.149         ICMP     98     Echo (ping) reply    id=0xf17a, seq=2/512, ttl=112 (request in 5)
      7 3.011402            172.17.30.149         8.8.8.8               ICMP     98     Echo (ping) request  id=0xf17a, seq=3/768, ttl=64 (reply in 8)
      8 3.017432            8.8.8.8               172.17.30.149         ICMP     98     Echo (ping) reply    id=0xf17a, seq=3/768, ttl=112 (request in 7)
      9 4.015589            172.17.30.149         8.8.8.8               ICMP     98     Echo (ping) request  id=0xf17a, seq=4/1024, ttl=64 (reply in 10)
     10 4.021430            8.8.8.8               172.17.30.149         ICMP     98     Echo (ping) reply    id=0xf17a, seq=4/1024, ttl=112 (request in 9)
     11 5.019150            172.17.30.149         8.8.8.8               ICMP     98     Echo (ping) request  id=0xf17a, seq=5/1280, ttl=64 (reply in 12)
     12 5.024961            8.8.8.8               172.17.30.149         ICMP     98     Echo (ping) reply    id=0xf17a, seq=5/1280, ttl=112 (request in 11)
However, during a time period when the loss is not occurring, we see the correct tags on the ether5 traffic:
      1 0.000000       30   172.17.30.149         172.17.20.10          ICMP     102    Echo (ping) request  id=0x767a, seq=690/45570, ttl=64 (no response found!)
      2 5.003249       30   172.17.30.149         172.17.20.10          ICMP     102    Echo (ping) request  id=0x767a, seq=691/45826, ttl=64 (no response found!)
      3 7.181256       30   172.17.30.149         8.8.8.8               ICMP     102    Echo (ping) request  id=0xce7b, seq=0/0, ttl=64 (no response found!)
      4 8.183193       30   172.17.30.149         8.8.8.8               ICMP     102    Echo (ping) request  id=0xce7b, seq=1/256, ttl=64 (no response found!)
      5 9.185224       30   172.17.30.149         8.8.8.8               ICMP     102    Echo (ping) request  id=0xce7b, seq=2/512, ttl=64 (no response found!)
      6 10.007561      30   172.17.30.149         172.17.20.10          ICMP     102    Echo (ping) request  id=0x767a, seq=692/46082, ttl=64 (no response found!)
      7 10.187223      30   172.17.30.149         8.8.8.8               ICMP     102    Echo (ping) request  id=0xce7b, seq=3/768, ttl=64 (no response found!)
      8 11.190535      30   172.17.30.149         8.8.8.8               ICMP     102    Echo (ping) request  id=0xce7b, seq=4/1024, ttl=64 (no response found!)
      9 12.191940      30   172.17.30.149         8.8.8.8               ICMP     102    Echo (ping) request  id=0xce7b, seq=5/1280, ttl=64 (no response found!)
     10 15.009029      30   172.17.30.149         172.17.20.10          ICMP     102    Echo (ping) request  id=0x767a, seq=693/46338, ttl=64 (no response found!)
     11 20.014121      30   172.17.30.149         172.17.20.10          ICMP     102    Echo (ping) request  id=0x767a, seq=694/46594, ttl=64 (no response found!)
     12 25.017964      30   172.17.30.149         172.17.20.10          ICMP     102    Echo (ping) request  id=0x767a, seq=695/46850, ttl=64 (no response found!)
     13 30.022025      30   172.17.30.149         172.17.20.10          ICMP     102    Echo (ping) request  id=0x767a, seq=696/47106, ttl=64 (no response found!)
And, likewise, we see both ping destinations showing up correctly on a capture of vlan30 traffic:
      1 0.000000            172.17.30.149         8.8.8.8               ICMP     98     Echo (ping) request  id=0xd27b, seq=0/0, ttl=64 (reply in 2)
      2 0.006248            8.8.8.8               172.17.30.149         ICMP     98     Echo (ping) reply    id=0xd27b, seq=0/0, ttl=112 (request in 1)
      3 1.005186            172.17.30.149         8.8.8.8               ICMP     98     Echo (ping) request  id=0xd27b, seq=1/256, ttl=64 (reply in 4)
      4 1.011153            8.8.8.8               172.17.30.149         ICMP     98     Echo (ping) reply    id=0xd27b, seq=1/256, ttl=112 (request in 3)
      5 2.009529            172.17.30.149         8.8.8.8               ICMP     98     Echo (ping) request  id=0xd27b, seq=2/512, ttl=64 (reply in 6)
      6 2.015652            8.8.8.8               172.17.30.149         ICMP     98     Echo (ping) reply    id=0xd27b, seq=2/512, ttl=112 (request in 5)
      7 2.383880            172.17.30.149         172.17.20.10          ICMP     98     Echo (ping) request  id=0x767a, seq=701/48386, ttl=64 (reply in 8)
      8 2.384287            172.17.20.10          172.17.30.149         ICMP     98     Echo (ping) reply    id=0x767a, seq=701/48386, ttl=63 (request in 7)
      9 3.014246            172.17.30.149         8.8.8.8               ICMP     98     Echo (ping) request  id=0xd27b, seq=3/768, ttl=64 (reply in 10)
     10 3.020182            8.8.8.8               172.17.30.149         ICMP     98     Echo (ping) reply    id=0xd27b, seq=3/768, ttl=112 (request in 9)
     11 4.018495            172.17.30.149         8.8.8.8               ICMP     98     Echo (ping) request  id=0xd27b, seq=4/1024, ttl=64 (reply in 12)
     12 4.024680            8.8.8.8               172.17.30.149         ICMP     98     Echo (ping) reply    id=0xd27b, seq=4/1024, ttl=112 (request in 11)
     13 5.021400            172.17.30.149         8.8.8.8               ICMP     98     Echo (ping) request  id=0xd27b, seq=5/1280, ttl=64 (reply in 14)
     14 5.027179            8.8.8.8               172.17.30.149         ICMP     98     Echo (ping) reply    id=0xd27b, seq=5/1280, ttl=112 (request in 13)
     15 7.383943            172.17.30.149         172.17.20.10          ICMP     98     Echo (ping) request  id=0x767a, seq=702/48642, ttl=64 (reply in 16)
     16 7.384349            172.17.20.10          172.17.30.149         ICMP     98     Echo (ping) reply    id=0x767a, seq=702/48642, ttl=63 (request in 15)
Relevant configuration is as follows:
# jul/12/2021 00:12:34 by RouterOS 6.47.10
# software id = KQ9B-0VZ3
# model = RB3011UiAS
set 0 vlan-mode=secure
set 1 vlan-mode=secure
set 2 default-vlan-id=20 vlan-mode=secure
set 3 vlan-mode=secure
set 4 default-vlan-id=30 vlan-mode=secure
set 5 vlan-mode=secure
set 6 vlan-mode=secure
set 7 vlan-mode=secure
set 8 vlan-mode=secure
set 9 vlan-mode=secure
set 10 vlan-mode=secure
set 11 vlan-mode=secure
add independent-learning=yes ports=switch1-cpu,ether1,ether2 switch=switch1 vlan-id=1
add independent-learning=yes ports=switch1-cpu,ether1,ether2,ether3 switch=switch1 vlan-id=20
add independent-learning=yes ports=switch1-cpu,ether1,ether2,ether5 switch=switch1 vlan-id=30
add independent-learning=yes ports=switch1-cpu,ether1,ether2 switch=switch1 vlan-id=40
add independent-learning=yes ports=switch1-cpu,ether1,ether2 switch=switch1 vlan-id=41
add independent-learning=yes ports=switch1-cpu,ether1,ether2 switch=switch1 vlan-id=50
add independent-learning=yes ports=switch1-cpu,ether1,ether2 switch=switch1 vlan-id=2
add independent-learning=yes ports=switch2-cpu,ether6,ether7,ether8,ether9,ether10 switch=switch2 vlan-id=1
add name=lan priority=0x2000
add arp=disabled fast-forward=no name=loopback protocol-mode=none
add name=wan protocol-mode=none
add bridge=wan interface=wan-ports
add bridge=lan interface=lan-ports internal-path-cost=1000000 path-cost=1000000
/interface vlan
add interface=lan name=vlan2 vlan-id=2
add interface=lan name=vlan20 vlan-id=20
add interface=lan name=vlan30 vlan-id=30
add interface=lan name=vlan40 vlan-id=40
add interface=lan name=vlan41 vlan-id=41
add interface=lan name=vlan50 vlan-id=50
add address=172.17.10.10/24 interface=wan network=172.17.10.0
add address=172.17.2.2/24 interface=vlan2 network=172.17.2.0
add address=172.17.0.1 interface=loopback network=172.17.0.1
add address=172.17.1.2/24 interface=lan network=172.17.1.0
add address=172.17.1.1 interface=vrrp1 network=172.17.1.1
add address=172.17.20.1 interface=vrrp20 network=172.17.20.1
add address=172.17.20.2/24 interface=vlan20 network=172.17.20.0
add address=172.17.30.2/24 interface=vlan30 network=172.17.30.0
add address=172.17.40.2/24 interface=vlan40 network=172.17.40.0
add address=172.17.41.2/24 interface=vlan41 network=172.17.41.0
add address=172.17.50.2/24 interface=vlan50 network=172.17.50.0
add address=172.17.30.1 interface=vrrp30 network=172.17.30.1
add address=172.17.40.1 interface=vrrp40 network=172.17.40.1
add address=172.17.41.1 interface=vrrp41 network=172.17.41.1
add address=172.17.50.1 interface=vrrp50 network=172.17.50.1
Any ideas? Please let me know if other captures or output would be useful in debugging this.
Users browsing this forum: Bing [Bot], GoogleOther [Bot], patrikg and 91 guests
