MUM Europe 2020
triac
ADSL 2+ PCI cards compatible with MT
Thu Aug 09, 2007 4:34 pm
Hi, Can anyone tell me if exist some ADSL2+ PCI card compatible with Mikrotik ROS?
If yes which card?
Thank You
Paolo
csickles
Re: ADSL 2+ PCI cards compatible with MT
Thu Aug 09, 2007 4:45 pm
None.
You must use external modem.
Provide ethernet port.
Craig
triac
Thu Aug 09, 2007 4:56 pm
Hi Craig, Tnx for answer...
and You know some good modem/router?
I need to install a very stable and affidable product, not commercial "shit".
Can You suggest me some brand or model?
Paolo
csickles
Thu Aug 09, 2007 7:54 pm
I wish I could...
I have been asking for about 3+ years for ADSL, but there isnt enough demand..
I use a XyXel (I think that is the spelling)... Any ways.. they all seem to have cooling problems.
My Cisco (P.O.S.) had cooling issues. (would lockup after 1hr)...
The XyXel modem has been very stable after I cut a hole in the top and mounted a fan in it
It now has betrer cooling per sq. In. than most servers. (I also mounted a heat sink on one of the devices that has gettin a bit toasty...)
Nothing like haveing to rebuild someone's "Stuff"... (Replace "Stuff" with you favorite description)
Craig
triac
Sat Aug 11, 2007 1:03 am
Hi Craig,
I've found some Zyxel Prestige 662 HD modem, I'll try to apply a fan to it and I hope it work fine!
Tnx for answer
Paolo
Users browsing this forum: No registered users and 75 guests
