GiovanniG
recover a Mikrotik over another Mikrotik (same LAN)
Sat Jul 24, 2021 8:44 pm
Hi, trying to solve a problem remotely (WInbox) on Caps protocol I've unfortunately changed a wrong parameter on firewall, not the router isn't more available on internet but I guess it works fine if the source is located on the same LAN. I've access through Winbox on another Mikrotik on the same LAN, unfortunately this is not the gateway and I have only the winbox port natted on it.
Can I, using the terminal of the recheable router, open a connection on the unreachable router? For example telnet protocol, can I? or SSL, or any winbox emulation..
Thank you a lot
GiovanniG
Re: recover a Mikrotik over another Mikrotik (same LAN)
Sat Jul 24, 2021 8:57 pm
I've found telnet on istruments, unfortunately it doesn't answer from the local IPs too (((( but it replies to pings.
I guess I have no other chance than reset it. The problem is that this place is located 3 hours by car far from me :(
dmitris
Sat Jul 24, 2021 9:24 pm
Do you have configuration of your device? If yes, post it here without sensitive data.
Look in Neighbor Discovery, maybe it will available there...Also on locked device do you have configured mac-winbox-servrer or mac-telnet-server ?
GiovanniG
Sat Jul 24, 2021 10:27 pm
thansk a lot of answer, I've googled and print the neighbors, the target unreachabel router is 192.68.88.3
[admin@MikroTik] /ip neighbor> find
[admin@MikroTik] /ip neighbor> print
# INTERFACE ADDRESS MAC-ADDRESS
0 ether2... 192.168.88.2 2C:C8:1B:22:81:DD
bridge
1 ether2... 192.168.88.2 2C:C8:1B:22:81:DE
bridge
2 ether3... 192.168.88.3 08:55:31:37:88:00
bridge
3 ether3... 192.168.88.3 08:55:31:37:88:01
bridge
how can I access it? I've telnet it and sshe from 2 fifferent mikrotics and it doesn't answer,
no I don't have a backup of its config, provbably the wrong thing was to set the ethernet as a LAN interface instead of WAN as it was
I don't know the settings "mac-winbox-servrer or mac-telnet-server", I havent' touched them, do you mean I can telent the mac of the target router? Does it has sense?
GiovanniG
Sat Jul 24, 2021 10:34 pm
You gave me the idea, cool! I've never telnet a mac address! )) it opens, I've dumped the config, what I should change to revive it? Thank you!
[admin@MikroTik] > export
# jan/07/1970 06:47:35 by RouterOS 6.47.10
# software id = 6W5F-6GYH
# model = RouterBOARD wAP 2nD r2
# serial number = 6D820D3BF0DB
add name=bridge1
/interface wireless
# managed by CAPsMAN
# channel: 2447/20-eC/gn(28dBm), SSID: , CAPsMAN forwarding
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX distance=indoors frequency=auto \
    installation=outdoor mode=ap-bridge ssid=MikroTik-378801 wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=wlan1 name=defconf
add bridge=bridge1 interface=wlan1
add comment=defconf interface=wlan1 list=LAN
add comment=defconf interface=ether1 list=LAN
/interface wireless cap
set bridge=bridge1 discovery-interfaces=bridge1 enabled=yes interfaces=wlan1
add address=192.168.88.3/24 interface=bridge1 network=192.168.88.0
/ip dhcp-client
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new disabled=yes in-interface-list=WAN
add distance=1 gateway=192.168.88.254
/system ntp client
set primary-ntp=193.204.114.232 secondary-ntp=132.163.97.5
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] >
dmitris
Sun Jul 25, 2021 12:43 am
Does this router have a static public ip address ?
You have a default configuration on you router and it accept mgmt connections only from LAN at this moment.
dmitris
Sun Jul 25, 2021 12:52 am
You need to post configuration from main router also...
rextended
Re: recover a Mikrotik over another Mikrotik (same LAN)  [SOLVED]
Sun Jul 25, 2021 1:11 am
IF you do not have rebooted the router do /undo , and wait some seconds, sometimes, on router terminal until go back online as before...
GiovanniG
Sun Jul 25, 2021 9:40 pm
thank you mate, this is a precious post! :)) I've done it and I got it back, I hope the previous config is now automatically stored and if a reboot accours it will keep running
Users browsing this forum: armandfumal, Bing [Bot], DanMos79, helleon, Kanzler and 114 guests
