mtr
DHCP option 66 for provision server not working
Mon Aug 02, 2021 3:39 pm
Good morning
i set up a option under DHCP for option code 66 and for the server i did 'http://xx.xxxxx.com/provision' i assigned this option to my pool , under DHCP>networks, none of my phones get the provision URL we have a mix of yealink and polycom phones
what am i missing
any guideness and how to trouble shoot this ?
rextended
Re: DHCP option 66 for provision server not working
Mon Aug 02, 2021 3:52 pm
/ip dhcp-server export
mtr
Mon Aug 02, 2021 4:11 pm
# jan/08/1970 16:23:21 by RouterOS 6.47.1
# software id = SGQT-PP3L
# model = RB2011UiAS
# serial number = D51E0CA1CC67
add address-pool=dhcp_pool1 disabled=no interface=bridge name=dhcp1
/ip dhcp-server option
add code=160 name=option66 value="'http://fsxx.xxhone.cloud/app/provision/'"
/ip dhcp-server option sets
add name=set1 options=option66
/ip dhcp-server lease
add address=192.168.5.223 always-broadcast=yes client-id=1:80:5e:c0:db:7:53 mac-address=80:5E:C0:DB:07:53 server=dhcp1
add address=192.168.5.0/24 dhcp-option=option66 dns-server=8.8.8.8 gateway=192.168.5.1
rextended
Mon Aug 02, 2021 4:14 pm
option 66 has code 160 or.. 66???
code=160
mtr
Mon Aug 02, 2021 4:22 pm
I changed it to 160 because that's what I saw something on Google to try 160 if 66 doesn't work
rextended
Mon Aug 02, 2021 5:12 pm
The TFTP server work and the url is "provision/" or "provisioning/" ?
mtr
Mon Aug 02, 2021 5:21 pm
its an HTTP server not a tftp and the URL is provision
rextended
Mon Aug 02, 2021 5:22 pm
ok, if is not httpS, but http:// etc. open on web browser the link works?
mtr
Mon Aug 02, 2021 5:29 pm
Yes the web browser works
the problem is that i dont see the URL under the provision server field on the phone
nescafe2002
Forum Veteran
Forum Veteran
Mon Aug 02, 2021 5:54 pm
Have you enabled DHCP provisioning in the phone features? Or have you factory reset the phones to test?
(Yealink will only accept DHCP provisioning when enabled or after factory reset)
mtr
Mon Aug 02, 2021 5:57 pm
They are new phones but I will do a fscotory reset now
mtr
Mon Aug 02, 2021 6:50 pm
factory reset didnt help
nescafe2002
Forum Veteran
Forum Veteran
Mon Aug 02, 2021 7:52 pm
Then try enabling DHCP Provisioning: Settings > Auto Provision > DHCP Active > On
Then reset (reboot) phone.
Is your endpoint password protected? From a working setup:
add code=66 name=yealink value="'https://user:password@host.domain.tld:443/dms/yealink/'"
add address=192.168.21.0/24 dhcp-option=yealink gateway=192.168.21.254 netmask=24
Also, note that your static binding overrides the network setting, apparently. You may want to add the option here too:
add address=192.168.5.223 mac-address=80:5E:C0:DB:07:53 server=dhcp1 << add dhcp-option=option66
mtr
Mon Aug 02, 2021 8:52 pm
Dhcp option is on . On the phone
Iam going to try and do a packet capture
Users browsing this forum: No registered users and 92 guests
