Sahafi2001
I can't change the MAC address
Mon Aug 30, 2021 10:13 pm
Good evening, I want to change the MAC address of the router, but I can't. I tried the following commands, but to no avail
/interface ethernet set ether1 mac-address=33:10:C6:72:29:EB
This is what appears to me
[*******@********] > inter eth pr
Flags: X - disabled, R - running, S - slave
 #    NAME                                    MTU MAC-ADDRESS       ARP             SWITCH
 0 R  E1                                     1500 00:00:00:00:00:00 enabled         switch1
 1 RS E2                                     1500 00:00:00:00:00:00 enabled         switch1
 2 XS E3                                     1500 00:00:00:00:00:00 enabled         switch1
 3 XS E4                                     1500 00:00:00:00:00:00 enabled         switch1
 4 XS E5                                     1500 00:00:00:00:00:00 enabled
 5 XS E6                                     1500 00:00:00:00:00:00 enabled
 6 XS E7                                     1500 00:00:00:00:00:00 enabled
 7 XS E8                                     1500 00:00:00:00:00:00 enabled
 8 X  sfp-sfpplus1                           1500 00:00:00:00:00:00 enabled
 9 X  sfp1                                   1500 00:00:00:00:00:00 enabled
[*******@********] /interface ethernet> set 0 mac-address=33:10:C6:72:29:EB
failure: invalid mac address
I intentionally hid my MAC address
sindy
Re: I can't change the MAC address
Mon Aug 30, 2021 10:33 pm
What is the second symbol from the left (xX:xx:xx:xx:xx:xx) of the address you are trying to set?
Sahafi2001
Tue Aug 31, 2021 10:05 am
Number 3
ConnyMercier
Forum Veteran
Forum Veteran
Tue Aug 31, 2021 10:19 am
33:XX:XX:XX:XX:XX Isn't a valib MAC-Address ..
48-bit MAC addresses in the range 33-33-00-00-00-00 to 33-33-FF-FF-FF-FF are used for IPv6 multicast.
For Exemple : 34:XX:XX:XX:XX:XX will work
sindy
Tue Aug 31, 2021 10:42 am
Number 3
At this position, only even digits (0,2,4,6,8,a,c,e) are possible for an own MAC address of a device. If the least significant bit of this digit is 1, i.e. when the digit is odd, it indicates a group address that can only be used as a broadcast or multicast destination one, never as an own address.
Users browsing this forum: No registered users and 92 guests
