mahfuzazam
SSH Brute force Prevention
Fri Sep 10, 2021 11:59 am
Hi Guys,
I'm getting log messages stating "login failure for user oracle, dell, etc. from 218.92.153.5 via ssh"
I've followed the guideline from the link below.
https://wiki.mikrotik.com/wiki/Brutefor ... prevention
My configuration is below:
add action=drop chain=input src-address-list=blacklisted-ip
add action=add-src-to-address-list address-list=blacklisted-ip \
    address-list-timeout=3d chain=input connection-state=new dst-port=\
    21,22,23,8291,8728,8279 protocol=tcp src-address=!192.168.20.0/23 \
    src-address-list=stage-3
add action=add-src-to-address-list address-list=stage-3 address-list-timeout=\
    5m chain=input connection-state=new dst-port=21,22,23,8291,8728,8279 \
    protocol=tcp src-address=!192.168.20.0/23 src-address-list=stage-2
add action=add-src-to-address-list address-list=stage-2 address-list-timeout=\
    protocol=tcp src-address=!192.168.20.0/23 src-address-list=stage-1
add action=add-src-to-address-list address-list=stage-1 address-list-timeout=\
    3m chain=input connection-state=new dst-port=21,22,23,8291,8728,8279 \
Do I need to add additional firewall rules along with it? Since I keep getting that log. Please advise.
mkx
Re: SSH Brute force Prevention  [SOLVED]
Fri Sep 10, 2021 12:10 pm
I guess most of (advanced) forum users agree that management access to router should be allowed in "allow few, block the rest" manner ... your firewall is in manner "block a few, allow the rest" which opens huge window of opportunity to try to hack it (by using a distributed crowd of bots).
BTW, your top-most "drop blacklisted" rule would be better moved to /ip firewall raw like this
/ip firewall raw
add action=drop chain=prerouting src-address-list=blacklisted-ip
And check if the offending remote IP address did end-up on any of the address lists involved in your port scanning detection rules.
mahfuzazam
Fri Sep 10, 2021 12:29 pm
/ip firewall raw
I'm currently using the drop action in /firewall raw. So far, no log error is received.
But the following IP didn't end up in the blacklisted-ip list. Had to manually put it there. That's what is worrying me the most.
I'm planning on allowing ssh for few management IPs if I receive this once again. To be very safe.
Users browsing this forum: Google [Bot], saajid and 50 guests
