MichaelDC
Trigger Script when LTE receives IP address
Fri Sep 10, 2021 11:49 pm
I am wondering if it is possible to trigger a script when an LTE modem on a RB receives an IP address.
When teh LTE modem makes a connection the IP address is being added to the route list but is there any way to use that as a trigger? I would need to enable/disable an interface when this occurs.
Any help is appreciated.
Michaël
rextended
Re: Trigger Script when LTE receives IP address
Sat Sep 11, 2021 12:21 am
Is not possible to add a script to lte1 interface like other ppp connections.
You can check on scheduled script if the interface are obtained the IP or not:
:if ([:len [/ip add find where interface=lte1]] > 0) do={
    :put "IP obtained"
} else={
    :put "waiting for IP"
tdw
Sat Sep 11, 2021 12:22 am
The DHCP client can run a script, see https://help.mikrotik.com/docs/display/ ... DHCPClient
rextended
Sat Sep 11, 2021 12:23 am
Assuming than the user use a standard MikroTik device like SXT-R with R11e-LTE,
the lte1 (on default configuration) do not need any DHCP client...
If the user refer to other models not specified is another thing...
@MichaelDC please specify everything or else it will get confusing, thanks.
MichaelDC
Sat Sep 11, 2021 11:15 am
I use an RBM33G ROS v6.48 with 2 R11E LTE6 modules.
The DHCP client unfortunately doesn't see LTE1 and LTE2 so I can't trigger from there.
Using a scheduled script is a possibility but I would have preferred to trigger it from state change on the LTE itself to limit the time in which it is in an incorrect state.
Michaël
tdw
Sat Sep 11, 2021 3:37 pm
I had not remembered that lte interfaces themselves do not use the DHCP client - it is from using setups with passthrough. I don't know if you could abuse passthrough with an otherwise unused local interface or if the underlying network driver would foil this approach.
rextended
Sat Sep 11, 2021 3:42 pm
The "easy" soluction is: MikroTik must add on-up and on-down on all interface (also ethernet, wlan, etc.)
MichaelDC
Sat Sep 11, 2021 8:24 pm
I'll second that but might take a while
SiB
Sun Sep 12, 2021 1:36 pm
In units with one lte interface I add that action to my netwatch who detect if internet is UP or DOWN.... and at netwatch UP script I can do additional job's to do. Check my signature or post:
Additional Scripts for LTE
Users browsing this forum: alibloke and 113 guests
