ghostt
SSTP server with CRL, certificate import problem
Mon Sep 13, 2021 3:56 am
Hi guys,
I had a CCR1036 v6.46.xxx (sorry, can't remember what "xxx" was) working as a SSTP server with multiple clients connected to it. CRL was set as a CCR's local IP address (10.0.0.1, for instance). The router got physically burned. Having all backups and certificates it was very easy to configure a new CCR1036 and import server / CA certificates. However, none of the clients could connect. At the time with literally hundreds of clients screaming I couldn't give troubleshooting much time and I had to stop checking clients certificates. All SSTP clients reconnected to the new CCR immediately.
Is it possible to transfer server and CA signed with CRL certificates to a new hardware and I simply did something wrong? Or I had to generate new server, CA and a bunch of client certificates (which I had to do in the end)?
Any help would be appreciated.
Kind regards, and thank you in advance.
tukan
Re: SSTP server with CRL, certificate import problem
Mon Sep 20, 2021 10:43 am
Yes, it is possible to transfer the certificates. You have to export them first correctly. I would recommend doing the export/import procedure before actually going live.
Users browsing this forum: Bing [Bot] and 114 guests
