I am new to routeros. My home LAN is managed by a mikrotik router running RouterOS 6.48.4. My ISP has a firewall that blocks many websites. To get around this firewall, I am running privoxy on one of my home pc (IP 192.168.0.110, connected to ether5) and a PC outside the firewall and connect these two with a KCPTUN tunnel. To access the blocked website, I setup browsers to use the proxy at port 8118 (default port of proxy) of 192.168.0.110, and all the traffic are forwarded to outside PC over KCPTUN tunnel. It works great for all the blocked sites for both http and https protocols.
Now I want to set up ROS rules so that I don't need to set up proxies on every devices. I tried something like:
Code: Select all
ip firewall nat add action=dst-nat chain=dstnat dst-port=80 in-interface=ether2 protocol=tcp to-addresses=192.168.0.115 to-ports=8118
Please advise me what I should do.
I appreciate your help. Bridge information is as following. If other information is needed, please let me know.
Code: Select all
/interface bridge export
add name=bridge1
