MUM Europe 2020
nl0pat
msn audio not working behind NON-NATting setup
Tue Aug 21, 2007 1:50 am
I have my rb532 running v2.9.43 in a pretty straightforward firewall setup.
My isp gives me 'unlimited' public ip's, so I run my home network on public ip space 8) .
Now what I do is basically mark every packet going through the bridge and accept all incoming marked packets with my marking on it, also every established and related packet. Everythinge else goes straight to the binary waste bin. (is dropped)
This works flawlessly, but you should have guessed that I am having a small issue, why else should I write a posting on this board :)
My issue is that my msn messenger is not able to receive audio/video because I do not recognize that I would like this packets to go through my firewall. Because this setup is not initiated from my pc, but from the other side.
Does anyone have a suggestion ?
(UPNP does not seem to solve this problem, I guess because it is more intended for use behind a NAT router, not a firewall only)
TIA
LatinSuD
Re: msn audio not working behind NON-NATting setup
Thu Sep 06, 2007 8:48 pm
Use less restrictive firewall rules? Like only dropping "invalid" packets, but not new incoming.
Maybe you could configure a range/window of incoming ports to be always open? That is tell msn to use certain ports, and tell MT not to filter those ports.
Maybe MT could implement MSN related connection tracking, but that's another story.
nl0pat
Thu Sep 06, 2007 9:27 pm
I can not think of a way to distinguish "invalid" packets from valid packets. Unwanted packets like portscanning and such, are always new incoming (SYN packets)
Perhaps that's an option, but I do not remember seeing that kind of options in todays version of 'live messenger'. But I think I should give that a try. Thanks for the hint.
I don't think they do that, but if they do I would be very pleased with it.
Come on MT team, make my day :roll:
andrewluck
Forum Veteran
Forum Veteran
Sat Sep 08, 2007 12:09 pm
Do you have a compelling reason to use a public address space on your LAN? From a security standpoint this setup is a nightmare. As you've discovered, it's very difficult to secure this while keeping legitimate networking functions working.
My solution would be to bind your public addresses to the outside interface of the MT and do 1:1 NAT to your LAN. Some Messenger functions may require you to run uPNP.
Regards
Andrew
nl0pat
Mon Sep 17, 2007 9:48 am
Those multiple ip's are delivered by means of a dhcp server. How do you suggest to receive multiple dhcp leases on one physical interface ?
Furthermore, do you have any recommendations on the 1:1 NAT setup?
sergejs
Mon Sep 17, 2007 3:48 pm
MSN voice is using H.323, such helper exists at RotuerOS.
It should not be used unless NAT is not used at the network.
MSN should work fine at public addresses space, unless firewalls on ISP or your router are not blocking this traffic.
1:1 NAT configuration example is the following,
http://wiki.mikrotik.com/wiki/How_to_li ... Local_ones
nl0pat
Mon Sep 17, 2007 4:19 pm
Thnx sergejs,
Can you also answer my second question regarding the multiple leases on one physical interface?
(I presume this is not possible, but was wondering if there is some kind of solution for this)
sergejs
Tue Sep 18, 2007 4:04 pm
Why do you need multiple leases on the one physical interface ?
What is your configuration scenario goals ?
nl0pat
Tue Sep 18, 2007 10:11 pm
receive multiple leases, to do 1:1 natting with each of the public ip's as suggested.
Znuff
Wed Sep 19, 2007 6:15 am
if you plan on using that kind of restrictive firewall then just drop the public ip space, there's no reason for it if you don't accept NEW connections.
My 2 cents.
nl0pat
Wed Sep 19, 2007 6:54 am
My 2 cents.
You see whenever I have any service to offer to the world outside i can just accept that particular one. I am currently using this setup you know. Only thing is that I cannot do any special things on msn messenger (WLM) like audio,video,direct file transfers etc.
Users browsing this forum: apollo2k4, chirba4, lambert, simcard and 183 guests
