kapis
RC4 multicast package??
Fri Aug 31, 2007 10:45 am
changelog doesn't mention enything about the multicast. what does it do?
normis
Re: RC4 multicast package??
Fri Aug 31, 2007 12:11 pm
sorry, it doesn't work at the moment. it was included by mistake. in RC5-6 we will have a working one. description and manual will also be made. i suggest you to uninstall it
kapis
Fri Aug 31, 2007 2:38 pm
thanks for reply :)
CarulloS
Fri Aug 31, 2007 5:42 pm
There is not any functional difference between disabling a package and uninstalling it correct - except for the space consumed by the files in the flash?
I usually just disable stuff I do not need or want - but I just want to make sure the configs and the running code do not also have unnecessary stuff in there because I did not actually uninstall a package.
Thanks,
Scott
macgaiver
Tue Sep 04, 2007 2:49 pm
Ok let imagine for 1 moment that RC5 is out and we have working multicast package.
Can someone give me some suggestions or links - how can I, without investing any money, check this feature out.
And I am not talking about some multicast traffic generators - I am talking about real usable stuff
This is something new for me - so I would like to get a real practical task and get it working with RC5 multicast.
phendry
Sun Sep 30, 2007 11:01 pm
In RC5-6 we will have a working one. description and manual will also be made.
Really looking forward to seeing how you guys implement Multicast support. Will it still make RC6?
Diganet
Tue Oct 02, 2007 1:49 pm
You can use VLC for Multicast testing/broadcasting.
Regards
/Henrik
macgaiver
Wed Oct 03, 2007 9:51 am
Regards
/Henrik
Sounds interesting - could you provide step-by-step instruction???
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
kapis
Wed Oct 03, 2007 10:18 am
http://www.videolan.org/vlc/streaming.html
Here you can read all the documentation on multicast streaming with VLC :wink:
--KAPIS--
phendry
Wed Oct 03, 2007 12:11 pm
Tested that yesterday using Multicast and all seems well. Just need the Mikrotik package now ;) Would be really handy to have some form of media proxy builtin to MT so a stream can be multicast across our network then present a standard IP address at our boarder routers to provide uni cast at our gig peering points.
kapis
Thu Oct 04, 2007 8:17 am
hmmm, yesterday RC6 came out with multicast package, but I can't find where to configure it :( please someone help !!!
--KAPIS--
phendry
Thu Oct 04, 2007 2:09 pm
From terminal there are a few options under "/routing pim". Not had a chance to play yet but looks straight forward enough.
kapis
Thu Oct 04, 2007 3:41 pm
thanks :) already found that :wink:
--KAPIS--
phendry
Tue Oct 30, 2007 6:39 pm
Any joy testing the new Multicast package? Just about to do some tests myself but wanted to see how others had done and if there where any problems.
Users browsing this forum: No registered users and 93 guests
