MUM Europe 2020
avantwireless
3.0Beta4 Wireless 5.8Ghz performance
Fri Aug 31, 2007 7:10 pm
YES YES YES! It finally passes full speed traffic! Limiting out to 14.7mb/s udp ap->cpe with 133c and r52H. Not as fast as sometimes in the past but not crashing to zero either, This works! tcp was around 10.5mb/s all measured using mt bandwidth test and testing through the AP/CPE not to them....
THANK YOU!!!
Robert
Equis
Forum Veteran
Forum Veteran
Re: 3.0Beta4 Wireless 5.8Ghz performance
Sun Sep 02, 2007 11:39 am
Is this faster or as good as 2.9?
avantwireless
Sun Sep 02, 2007 6:22 pm
As far as I can tell, it's a little better. I have upgraded all 3.0beta6 to rc4 and the only problem is that I have one compex card that will now not talk 2.4-10 or 5 mhz channels... This is pretty weird... worked fine with beta6. And it's the only one that I was trying to do 10 or 5 mhz channels with.
janisk
Mon Sep 03, 2007 10:34 am
2ghz-10mhz should be solved in rc5 when it comes out
it is known bug we are working on that.
edit: same for 5mhz channels
Users browsing this forum: valnuke and 74 guests
