MUM Europe 2020
ravael
3.0 rc4 bug(probably)
Sat Sep 01, 2007 11:48 pm
Hi, I have big problem with rb333. I have had a rc1 firmware and try upgrade to rc4, so I'm uploaded the firmware to mt and rebooted the system. And... the blue led is shining, and i hear ONE beep. and noone after it. when i connect through the any lan port, Its reconect every one second. Didn't have serial cable ;/
fortakas
Re: 3.0 rc4 bug(probably)
Sun Sep 02, 2007 3:06 am
Make serial cable it and didn't have in next time problem!
http://www.mikrotik.com/testdocs/ros/2. ... serial.php
Router Side cSignal Direction Side (DB9f)
1, 6 CD, DSR IN 4
2 RxD IN 3
3 TxD OUT 2
4 DTR OUT 1, 6
5 GND - 5
7 RTS OUT 8
8 CTS IN 7
if you dint have (DB9f)
get from old cable modem or somthing like that :)
kvan64
Sun Sep 02, 2007 5:42 pm
what method did you use to connect - through winbox? telnet?
I bought mine serial cable from ebay similar to this for $3.
http://cgi.ebay.com/NULL-MODEM-SERIAL-U ... dZViewItem
VicNet
Thu Sep 13, 2007 5:40 pm
We have same problem.
When we upload package to rb it shows in files list , file type "file" ( should be "package" ).
And then after reboot rb is out of service.
Only netinstall helps. After netinstall another upgrade from winbox is ok.
Strange. :(
Czechu
Users browsing this forum: ttdd85 and 112 guests
