skynoc
web proxy redirect *.mgp *.zip *.exe to another proxy server
Wed Sep 05, 2007 12:18 pm
hi guys
anyboday has an idea how to redirect all the files extensions like .zip .exe .mpg etc to another proxy server ?
but i want to keep the others to the main proxy
regards
skynoc
sergejs
Re: web proxy redirect *.mgp *.zip *.exe to another proxy server
Wed Sep 05, 2007 4:32 pm
I think you may try with 'ip proxy direct', where you may specify what to resolve directly and what by parent-proxy.
skynoc
Wed Sep 05, 2007 8:29 pm
hello ,
thanks for your reply
i have 2 proxy servers , i want to make one server for http request only and the other for the download , i cannot send them to the direct
sergejs
Thu Sep 06, 2007 2:22 pm
Here you will find information about direct functionality,
http://www.mikrotik.com/testdocs/ros/2. ... php#7.53.4
hulk-bd
Thu Sep 06, 2007 3:12 pm
Dear Skynoc,
you have two proxy server, both of them are MT OS or other operating OS like linux? If you have 2 MT OS then why u want to separate http and other files like exe. mgp. zip etc? you can use 1 MT for your normal NAT and other firewall setting, and with 2nd MT OS you can make that only as a web proxy, I'm using this kinda setting in my network and having great performance with my web proxy. I have told about this in the "Mikrotik + Web Proxy Queueing is Impossible?" topic. but I think none have any faith on my solution huh huh huh.
N.B: You can also user your proxy server with linux(squid), it'll also work just fine.
skynoc
Thu Sep 06, 2007 6:34 pm
i have an MT box with web proxy > parent proxy redirected to an external proxy server (win2003 and isa with downlink via satellite) serves the http requests
what i want to do is to make another proxy server which serves only the download of files
i know a satellite provider can give us 16 mbit downlink for 150 euro monthly .
regards
Znuff
Mon Sep 10, 2007 12:49 am
I don't think Squid or any other proxy will comunicate properly with Win2003's ISA. Your best chance is to use Linux with Squid or RouterOS.
skynoc
Mon Sep 10, 2007 9:04 am
do you think it is better to replace the win2003 + isa with redhat + squid ?
Znuff
Mon Sep 10, 2007 7:17 pm
Yes, but not with Red Hat, unless you're willing to pay $1000 or whatever for an enterprise license. Use Ubuntu Server + Squid.
hulk-bd
Mon Sep 10, 2007 7:28 pm
Hey man, Red Hat linux Ver.9 is more then fine for this solution, no need to buy any expensive server for it.
skynoc
Tue Sep 11, 2007 9:40 am
thank you guys , i'll try to replace it with redhat ver 9 .
regards
Znuff
Wed Sep 12, 2007 1:18 am
RedHat 9 is seriously outdated and insecure and has reached End of Life for ages.
Squid packages might be insecure and exploitable. You can use debian or even ubuntu-server, and that actually works on a low-end computer like 233Mhz with 128MB of ram or something similar.
Please stop instructing users to install redhat 9. Even the fedora legacy project shut down.
http://www.fedoralegacy.org/
skynoc
Wed Sep 12, 2007 8:37 am
ubuntu has a nice interface , it is very simple for use
i m going to try
thank you guys
Users browsing this forum: No registered users and 76 guests
