MUM Europe 2020
mag
router with web-proxy enabled crashes
Sun Jan 16, 2005 12:14 am
a few days ago i enabled the web-proxy on a mt router with fairly high traffic. since then the system has crashed completely (hardware reset necessary) every day and the log has often this error line:
Web-proxy error while running: squid was killed with signal11, restarting
system is a p3 pc with 4 intel-NICs, 128 mbyte RAM, router os 2.8.22 on CF and a 10 gbyte IDE-hd as cache drive. cpu load is usually below 20 percent. the proxy is running as transparent proxy with the usual dst-nat rules in place. the router is running mainly as PPPoE-server and has OSPF enabled.
anyone with similar problems or an idea?
tia.
   matthias
Cameron Earnshaw
Sun Jan 16, 2005 3:49 am
The web proxy is not stable in my opinion. I have started turning it off in most of my machines because I just can't trust it.
maximan
Trainer
Trainer
Mon Jan 17, 2005 2:55 pm
I upgrade to 2.8.22 and the web proxy is slow. If i stop it the navigation is fast, but if i enabled it is turn slow
M.
ofasa
Tue Jan 18, 2005 1:35 pm
Try increasing RAM, reducing diskspace used by cache, making sure drive doesn't have errors.
Alessio Garavano
Mon Jan 24, 2005 5:11 am
Try limiting Cache Size in the HDD to 2Gb or less...
Regards
Alessio Garavano
http://www.isparg.com.ar
ajmal
Re: router with web-proxy enabled crashes
Mon Jan 31, 2005 9:46 pm
as u mentioned her u have 10GB HDD then at least 16 MB of required per GB either u increase RAM or decrease cache space
Users browsing this forum: allevot, Cascuda, FRANKMUNOZ, jkjkrules, seho and 99 guests
