airnet
Uptime Challenge!
Tue Sep 18, 2007 1:27 pm
Who says cost effective = unreliable?
Still running 2.9.26 without a glitch for almost a year now.
sten
Forum Veteran
Forum Veteran
Re: Uptime Challenge!
Tue Sep 18, 2007 6:57 pm
the same people who said the latest version is best?
this was 2.8.26 btw
changeip
Tue Sep 18, 2007 7:07 pm
2.9.26 seems popular : )
[@br2] > /system resource print
uptime: 58w5d10h1m32s <- 411d
version: "2.9.26"
free-memory: 861212kB
total-memory: 905764kB
cpu: "Intel(R)"
cpu-frequency: 2992MHz
cpu-load: 3
free-hdd-space: 1885948kB
total-hdd-space: 1959016kB
write-sect-since-reboot: 49865424
write-sect-total: 55303064
sergejs
Wed Sep 19, 2007 8:55 am
Woh, great uptime.
balimore
Forum Veteran
Forum Veteran
Wed Sep 19, 2007 9:55 am
Hai frens
congratulation for all, and why anyone else restart needed...?
i love your uptime. :wink:
regards
Hasbullah.com
nordex
Wed Sep 19, 2007 4:47 pm
Just don't touch it.
It'll work.
omega-00
Fri Sep 21, 2007 2:57 am
Needs to be some sort of dude tool to check this.. have to go over about 20 or so devices :-P
jp
Long time Member
Long time Member
Fri Sep 21, 2007 2:39 pm
here
sten
Forum Veteran
Forum Veteran
Fri Sep 21, 2007 4:44 pm
changeip
Tue Dec 18, 2007 8:55 am
I don't know why but one of my routers has rolled over it's uptime.
BGP sessions have been up longer than the uptime counter.
[@br2] routing bgp peer> print status
Flags: X - disabled
0 name="l3" instance=ebgp-1 remote-address=x remote-as=3356
tcp-md5-key="" multihop=no route-reflect=no hold-time=3m ttl=60
in-filter=level3-in out-filter=level3-out remote-id=x
uptime=8w1d23h28m42s prefix-count=11 remote-hold-time=3m
used-hold-time=3m used-keepalive-time=1m refresh-capability=yes
state=established
1 name="br1" instance=ebgp-1 remote-address=x remote-as=x
tcp-md5-key="" multihop=no route-reflect=no hold-time=3m ttl=1
in-filter=ibgp-in out-filter=ibgp-borders remote-id=x
uptime=17w6d23h8m33s prefix-count=733 remote-hold-time=3m
state=established
[@br2] routing bgp peer> /system resource print
uptime: 4d21h25m23s
version: "2.9.26"
free-memory: 860768kB
cpu: "Intel(R)"
cpu-load: 2
free-hdd-space: 1885632kB
write-sect-since-reboot: 61887520
write-sect-total: 67325160
Somehow I went from 450+ days to rolling it over. I know the router didnt reboot. Weird.
Sam
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
changeip
Wed Dec 19, 2007 11:07 pm
yep, time rolled over at approximately 496 days. Sten, can you check to see if your 490 day box rolled its time over already ? Just curious if it was my box only or some limit on uptime days in RouterOS.
Sam
jonmansey
Thu Dec 20, 2007 6:31 am
afaik uptime is measured in ticks which are 100th of a second.
2^32 = 4294967296
so 2^32 ticks = about 497.1 days.
Im guessing they only use 32 bits long counter for uptime. hence the rollover.
jm
changeip
Thu Dec 20, 2007 6:37 am
thats exactly it! so I supposed the uptime challenge ends at 497 days. bummer. maybe MT can change that to a 64 bit counter so in 2 years from now we can look back and still be counting.
normis
Thu Dec 20, 2007 4:41 pm
we'll try to fix it, thanks :)
caspat
Sat Apr 05, 2014 6:56 pm
Not Bad! ;)
ccdevnull
Tue May 06, 2014 8:39 am
Uptime bug in routeros 5.22 ppc?
My uptime should be slightly more than 500days now. But it only shows 4 days.
But my PPPoE connection is 477 days (as it should be).
Is there a bug in routeros that it doesn't show uptime above 500 days correctly?
brainy
Thu Oct 02, 2014 2:18 pm
7 years later and still not fixed :(
ste
Thu Oct 02, 2014 2:30 pm
This is what a BGP Router should do. Just run :-)). RB1000 was a great device and 5.25 is the version which runs. Hope to see 6.25 anytime soon ;-)).
[admin@gw18] > system resource print
uptime: 56w3d10h23m34s
version: 5.25
free-memory: 1250708KiB
total-memory: 1555512KiB
cpu: e500v2
cpu-count: 1
cpu-frequency: 1333MHz
cpu-load: 16%
free-hdd-space: 25800KiB
total-hdd-space: 61440KiB
write-sect-since-reboot: 18704950
write-sect-total: 23133082
bad-blocks: 0%
architecture-name: powerpc
board-name: RB1000
platform: MikroTik
[admin@gw18] >
lbarbosa
Mon Mar 16, 2015 5:34 pm
RB2011 w/OSPF, MPLS, QueueTree and Firewall rules running smoothly for almost a year!! Approx. 25 clients connected to site and a few PtP's. No restart needed, great!
[cnc@Site 26 (Panorama)] > system resource print
uptime: 45w6d19h36m53s
version: 6.12
build-time: Apr/14/2014 09:27:45
free-memory: 33.3MiB
total-memory: 64.0MiB
cpu: MIPS 74Kc V4.12
cpu-count: 1
cpu-frequency: 600MHz
cpu-load: 12%
free-hdd-space: 48.5MiB
total-hdd-space: 64.0MiB
write-sect-since-reboot: 1388868
write-sect-total: 2096657
bad-blocks: 0%
architecture-name: mipsbe
board-name: RB2011L
platform: MikroTik
brainy
Mon Mar 16, 2015 5:41 pm
We have many RouterOS boxes where the uptime counter has overflowed many times, so some of the boxes have many years of uptime ...
CyB3RMX
Tue May 24, 2016 10:18 pm
One busy AP
- Toughput of +/- 43mbps,
- 52 CPE's registered
on a RB711GA-5HnD running 6.29.1 for almost a year without reboot.
Have a great day!
Certified: MTCNA - MTCWE - MTCRE
Chupaka
Wed Jun 01, 2016 2:32 pm
1 year uptime, almost 10 pebibytes of data transferred, 2,6 Gbps average traffic :)
[admin@BR] > :put [ /sys reso get uptime ]
52w1d18:09:13
[admin@BR] > :put ([ /int get ether3 tx-byte ] / 1024 / 1024 / 1024 / 1024)
9456
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
G2Dolphin
Mon Oct 02, 2017 2:41 pm
Nowhere to proof it have jumped over 32-bit counter (cmon, MikroTik, you're trying to fix that almost for 10 years :)), but that last link up time from the future... :)
121 days + 497 days of counter limit = 618 days as for now.
Home: RB3011UiAS-IN (2011 case+3011-RM), hAP ac, mAP2n/mAP2nD, GrooveA-52HPn, hEX (r3), hAP lite, RB951G-2HnD
Work: RB2011UiAS-RM / UiAS-2HnD-IN, RB951G-2HnD, hEX (r3), CRS125-24G-1S-2HnD-IN, CCR1009-8G-1S-1S+
BartoszP
Mon Oct 02, 2017 3:52 pm
Not so good but not so bad :-)
Real admins use real keyboards.
49er
Mon Oct 02, 2017 4:03 pm
If security is no problem then the uptime is nice.
But if you make updates than you can't see this uptimes in Mikrotik because you need a reboot after you upload a new version.
aacable
Tue Oct 03, 2017 2:21 pm
& upgrading is very frequent in the ROS ;) , specially with the new 6.x breed, we see fixbug/upgrade releases very quickly some times every 10-15 days.
_____________
Regard's
Syed Jahanzaib
Web: http://aacable.wordpress.com
Email: aacable [at] hotmail.com
Users browsing this forum: No registered users and 95 guests
